Results 1 to 3 of 3
Thread: brake lines
    Default brake lines
    i want some extended steel braided brake line and dont know what to get please help
    Jan 2007
    East Tennessee
    I got some extended braided lines for my truck. I don't know part numbers. I just removed my old lines, took them to Royal Brass and Hose and asked them to "copy" the old lines except with braided hose and longer. It seems like it was around $50 or $60 for all three lines. You should be able to do the same at any hydraulic shop. Good luck.
    You probably will end up having them made, because most stuff that is off the shelf will be for disc brake equipped vehicles and usually has a banjo type fitting at the end, rather than a connection for the wheel cylinder.
  1. Brake lines -Dana 60 chevy
    By Tomahawk715 in forum Modified Tech
    Last Post: March 29th, 2009, 08:49 PM
  2. Brake Flex-lines
    By fng in forum Modified Tech
    Last Post: February 28th, 2009, 07:15 PM
  3. Why are the rear brake lines 1/4 inch?
    Last Post: September 8th, 2008, 12:04 PM
  4. Rubber (or flex) brake lines?
    Last Post: June 6th, 2008, 11:41 AM
  5. Longer rubber brake lines...where to buy?
    By Nuke_spicergear in forum Modified Tech Archives
    Last Post: May 25th, 2004, 11:50 PM
