Results 1 to 3 of 3
Thread: Body Springs
    Default Body Springs
    How I missed this, I don't know. While painting the truck cab, I noticed the body to frame (cab) bolts were loose. I just assumed they worked loose till I got out the '34P and see there were once springs in there. Since they are gone, rusted away I guess, the bolts have no tension. Anyone know why they had these springs in there and if I need to replace them or just tighten them up and eliminate them?
    You should but them back, they are to keep the cab a little flexible and reduce stress and cracking of the sheet metal.
    68 M-715 MVPA #2710
    Flex like stated above.
    If you need springs, valve springs from a junk engine work great. I think the torque on those bolts with the springs is around 25 ft-lbs. I just get tension on them and go another turn or two since getting a torque wrench on those bolts is not always the easiest.
  1. coil springs and leaf springs ?
    Last Post: April 4th, 2010, 01:13 PM
  2. stock leaf springs vs custom leaf springs
    By japsk8 in forum Modified Tech
    Last Post: December 11th, 2009, 01:02 PM
  3. Big Springs
    By jeepjunker in forum Modified Tech
    Last Post: July 7th, 2009, 11:55 PM
  4. springs
    By lee brown in forum Open Discussion
    Last Post: March 9th, 2007, 09:54 PM
  5. Springs
    By carmen in forum Open Discussion
    Last Post: January 17th, 2007, 01:31 PM
