Results 1 to 7 of 7
Thread: Steering shaft size.
    Default Steering shaft size.
    I would like to inquire if anyone knows the diameter of the shaft on the stock steering column. I am looking to purchase a weld on quick release for my grant steering wheel. They are sold by shaft width. If I had one available to measure I wouldn't bother you guys but Im not located near one currently. TY
    Sorry for the slowness....
    Do you want to outer tube size where the wheel mounts or ?
    The size I am looking for is the diameter of the actual shaft, where the quick disconnect would weld onto. I dont want to be a hassle...more if someone had a general idea or one easily accessed. I'll be back around my 715 in about a week so if nobody has easy access I can pull mine apart then. TY for any response Brute.
    I think I have a column out of a truck...will take a look in a bit...
    For some reason, I cannot find my micrometer...best I can do is try to measure with a tape measure...how precise do you need?
    im pretty sure the adapters are based on 1/4 inches...so closest to that is cool.
    The shaft is 3/4" round. I know this because I modified the bottom of mine to work with a 3/4 DD u-joint.
    1967 M715 w/ 454 and TH400
  1. has anyone rebuilt the steering shaft ujoint?
    By Duane in forum Stock Tech
    Last Post: March 21st, 2010, 09:50 PM
  2. gimpyrobb : Steering shaft bushing ?
    By gimpyrobb in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 12:31 AM
  3. u-joint steering shaft.
    By alosix in forum Modified Tech
    Last Post: June 22nd, 2007, 03:41 PM
  4. Steering shaft u-joint type anyone use?
    By tngreenmachine in forum Modified Tech
    Last Post: March 16th, 2007, 02:48 PM
  5. Steering shaft question?
    By spr-m715 in forum Modified Tech
    Last Post: January 2nd, 2007, 08:41 AM
