Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: LED tail light conversion
    Yeah, I s'pose I could.... But I anticipate the LED light (when I get it) will fit in there pretty snugly as it is. Smear a little something around the perimeter of the light before it goes in and I'd be golden, eh?
    I'm still just baffled/befuddled over the fact that I am left with no lip....
    Oh, and good one, Jester.
    -- Tim Taylor
    Washington State
    4" is 4" but inside diameter is different than outside diameter when measuring your cutting device. Sounds like you use a 4" inside diameter hole saw when DP used a 4" outside diameter hole saw. Make sense?
    Nov 2008
    Tacoma, Washington
    Tim, use a marine grade adhesive > 3M's 5200 (black or Bronze color) or
    Sikka-Flex. These adhesives require 120+ degree heat to loosen up after once having cured. Clean squeeze outs with denatured alcohol. Careful this stuff likes to get on everything and use gloves or you'll have to wear it off.
    Where did the LED light come from?
  5. #15
    Lots of places sell the 4 inch rounds...same one semi trucks and trailers use...Grote, Truck Lite among others have them.
  1. Another 12v blackout hood light conversion
    By randyscycle in forum Modified Tech
    Last Post: March 3rd, 2021, 06:41 AM
  2. tail light brackets
    By jkrobbie in forum Stock Tech
    Last Post: April 23rd, 2009, 03:06 PM
  3. Tail light feedback
    By SHOOTER68 in forum Open Discussion
    Last Post: October 11th, 2008, 08:51 PM
  4. Who was making the aluminum tail light rings?
    By Binford in forum Open Discussion
    Last Post: June 19th, 2008, 11:57 PM
