Results 1 to 10 of 14
Thread: M715 vs M725 Parts
    Jun 2014
    Eastern Maine
    Default M715 vs M725 Parts
    Are the front fenders, front sheet metal and frame/chassis the same? Plan is to part out a M725 to repair a M715. Thank you.
    Aug 2015
    Portlandia, Oregon USA
    My thoughts:
    • The firewall and everything forward of that is the same as the 715. The fenders look the same, but I'm not positive about the mounting holes at rear of the front fenders
    • The windshield cowling and windshield frame is different than the 715
    • The 725 frame is almost the same except for the lack of hole in the rear crossmember for the pintle hook that the 715 has.
    • Not positive that all the rear truck bed body mounting pads on the frame are the same between the 715 and 725.
    • also- all the 725 door parts are different than the 715
    • Gas filler neck is also different
    1969 M725 ambulance
    Jun 2014
    Eastern Maine
    Thank you, took a look at the M725 today and your observations appear to be correct.
    Feb 2004
    Silver Lake Sand Dunes MI
    Yes, all those parts are the same between the M715 and M725. Even some of the dash and cab floor and front seats are the same.
    Dave
    Jun 2014
    Eastern Maine
    Thank you, so do you think the frame will work with a M715 body by adding the pintle hook features ?
    Feb 2004
    Yes, I believe the frames are the same except for the pintle. To add the pintle you will need the sleeve and plate from the M715 frame, then drill the hole and weld it into the M725 frame. Should be an easy swap.
    Dave
    Jun 2014
    Eastern Maine
    OK, thank you Dave. I will start a new thread for the restoration project. I have done a lot of MV restorations however this is the first M715 and will have a lot of questions I'm sure.
    Sep 2014
    Southern New Hampshire
    Was that 725 in nh? Milford I think, saw the Craigslist ad, and am wondering if it's the same one, I'm thinking about grabbing it for parts.
    Quote Originally Posted by m38inmaine View Post
    Sent from my SM-S920L using Tapatalk
    Jun 2014
    Eastern Maine
    Yes, met with him Sunday, making arrangements now to go back and bring it home Wednesday.
    Sep 2014
    Well good luck, and be sure to post plenty of pictures in a build thread, I look forward to it!
    And perhaps it will make me work a little harder at mine...too much work now though, not enough play time.
