Results 1 to 2 of 2
Thread: Trouble with PTO governor
    Default Trouble with PTO governor
    Hi All,
    I have a 1968 M724 SCEM Army Contact Maintenance Truck, my problem is the governor is not allowing normal throttle to operate when the PTO is disengaged, I haven't found any information in the TM's for M715's?
    Noel
    First, this should be in the stock forum...so I will move it there...
    As to your question...it works right when the pto is engaged and not when disengaged? Thats a new one on me...
    I know that you can remove it by taking the carb off, removing the gov. and getting shorter studs for the manifold...cap the vacuum line off and reinstall the carb and you are good to go...or you can buy, last I saw, the governor unit NOS and replace the one you have...
