Old December 1st, 2008, 10:46 AM
phoenix's Avatar
phoenix phoenix is offline
Private 1st Class
phoenix is a Soldier
Default 230 smoke
I would just like a consensus on what would be wrong with my original 230. The motor has 17,000 miles on it. It starts instantly and runs great for the first 3 minutes with no smoke at all not even a puff of smoke on start-up. after 3 minutes it creates a huge smoke cloud behind the truck and looking at the motor, I see oil literally boiling out of three crack in the exhaust manifold. All the smoke is coming out of the exhaust pipe though. I would think its the rings but not 100% A guy may be interested in buying all the original parts I have pulled out, so I would like to tell him how much work he's looking at.
Old December 1st, 2008, 11:40 AM
Barrman's Avatar
Barrman Barrman is offline
Chief 9-flats
Barrman is a Soldier
The standard rule is a puff of blue on start up and you have bad valve seals. A blue cloud while running at idle is rings.
However, is yours a white or blue cloud? White means water is burning or rather flashing to steam and indicates a blown head gasket.
Old December 2nd, 2008, 04:34 PM
phoenix's Avatar
Private 1st Class
I cant remember, its been 6 months since I pulled the motor out. If the head gasket was that bad wouldn't it smoke right away instead of after about three minutes though? I could do a compression test but I don't have all the tools to pull the plugs. besides all the smoke the motor ran great.
Old December 2nd, 2008, 05:10 PM
chicklin's Avatar
chicklin chicklin is offline
Private 1st Class
chicklin is a Soldier
Change the oil and replace one quart with a quart of Lucas Oil. It helped the smoke on my last one a bit.
1967 M715 w/w #11812
Old December 2nd, 2008, 06:26 PM
saxon saxon is offline
Corporal
saxon is a Soldier
Just a guess, It could be that once the engine warms up a little it expands and allowes the coolant to squirt past the compromised gastet???
  #6
Old December 2nd, 2008, 06:58 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
If they are stock military plugs and wires, you can get the wires off with a wrench and the plugs can be removed by gettin the deepest deep socket you can find in that size and using it...it will reach.
You can cut the side out of a socket, like an O2 sensor socket is made, and use that on the plug wires as well.
White smoke and a lack of power??? Docthrush Stock Tech 15 April 15th, 2010 07:18 AM
tomkirkman : Lots of Smoke, Oh no. PseudoZone PseudoZone - Open Archive 6 November 10th, 2009 11:14 PM
pistolnut : oil smoke PseudoZone PseudoZone - Open Archive 4 November 10th, 2009 08:31 PM
magic smoke noreallyicanfixit Stock Tech 6 February 2nd, 2009 05:29 PM
Started, Died, Smoke & Fire! JDS Open Discussion 7 August 18th, 2008 02:18 PM
1998 - 2019
Copyright 1998-2019
