Results 1 to 6 of 6
Thread: sweeney : How much does the bed weigh?
    Default sweeney : How much does the bed weigh?
    Post by sweeney on Apr 23, 2006, 3:07pm
    I'm planning on removing the bed from my truck next weekend, just wanted to make sure the hoist im using will be able to handle it.
    Geneva, FL
    Blog Entries
    1
    Default teking :
    Re: How much does the bed weigh?
    Post by teking on Apr 23, 2006, 4:12pm
    i seem to remember someone saying around 500lbs.
    Default barrman :
    Post by barrman on Apr 23, 2006, 5:29pm
    4 big guys can pick it up and actually move it.
    Others have also commented that the lifting eyelets at the corners will bend over if you attach to them without any kind of support for them. You might do better to run a pipe in the back and another in the front and then left off of that.
    Default brute4c :
    Post by brute4c on Apr 23, 2006, 8:13pm
    A couple people have estimated 600-700 lbs....estimate being the key word...
    Default sweeney :
    Post by sweeney on Apr 23, 2006, 8:18pm
    Thanks guys, the hoist I will be using is rated to 800 pounds with the boom fully extended, sounds like I won't have any trouble.
    Default 7521 :
    Post by 7521 on Apr 23, 2006, 8:28pm
    Crap. I did this last summer and I think ours was more than 500lbs(over head crane at the sand blaster read more like 600lbs.) I do know that the thing is HEAVY. I lifted it my self with a few chains and a "come- a -long", and a few creaking roof trusses in the pole barn. BTW I'm one of those guys that bent the lifting eyes, however nothing that a big adjustable wrench wouldn't bend back. Wish I had known about the pipe trick back then.
  1. sweeney : Got my cab back from sandblasting
    Last Post: November 12th, 2009, 06:11 AM
  2. sweeney : How much should sand blasting cost?
    Last Post: November 12th, 2009, 04:16 AM
  3. sweeney : POR-15 ?s
    Last Post: November 11th, 2009, 01:07 AM
  4. sweeney : Cab floor thickness
    Last Post: November 11th, 2009, 12:26 AM
