  #21
Old November 11th, 2009, 12:04 AM
Moderator
PseudoZone is a Soldier
Default robertcowan :
Re: Doubler X-Member
Post by robertcowan on Jun 7, 2006, 5:01pm
what about just using a 3/8ths steel plate and fab mounts for all the t-cases and trans mount then mounts to install it to the truck frame ? this would kill both the mount and skid plate with 1 deal.
bob
  #22
bluesman2a bluesman2a is offline
Private 1st Class
bluesman2a is a Soldier
Default bluesman2a :
Post by bluesman2a on Jun 7, 2006, 8:39pm
bob
Yep that would do it too, Bob... But for me there are several downsides talking plate vs tube:
1) have you priced plate recently? remember I just had all this laying around.
2) plate would need stiffening ribs, tube won't flex/sag the same way.
3) Not all the mounting surfaces are in the same plane (Xfer's stick out below) so you would have to clearance it. Not as much work as I did, but still a PITA.
4) Weight... This truck is by no means svelt, but I CAN lift the entire x-member myself and install it. No way you could do that with plate (a 4X4' sheet of 3/8 is almost 250 pounds, my entire assembly is approximately 30-40 without the sheet on the bottom).
I'm quite positive there are better ways to do this than what I did, but hopefully I won't be redoing this one myself!!!
  #23
Moderator
Post by robertcowan on Jun 8, 2006, 8:18pm
i wasnt knocking your work or engineering i complement you to the max. just thinking outloud. lookin good and you inspired me tremendously. thanks
bob
  #24
Moderator
Default elliott :
Post by elliott on Jun 11, 2006, 8:21am
Not only looks trick, but you can run your exhaust right through the X-member
  #25
Moderator
Default pinball :
Post by pinball on Jun 11, 2006, 10:15am
I like the looks of it... the concept for sure. I might have to get me a square tube die ....thats pretty sweet. One question.... can you remove the transmission pan while it's all bolted into truck?
Nice work from what I see
NoRM
  #26
Old November 11th, 2009, 12:05 AM
Private 1st Class
Post by bluesman2a on Jun 11, 2006, 12:05pm
bob
Oh I didn't take it that way at all Bob!!! I tend to be pretty hard on my work my own-self. I like "simple" on these rigs. "Simple" works, and keeps working, but complicated just lets you down every time at the worst time.
I think this project was only as complicated as it needed to be, but that's still more than I like.
And thank you sir for the kind words!
  #27
Private 1st Class
Post by bluesman2a on Jun 11, 2006, 12:12pm
Careful there Norm, any place you can keep the angles in a single plane and it's all 45 or 90*, square works well. Once you get into compound angles at odd places, the round stuff is still better (there were a couple of places on this one, around the 205 mount I was wishing for round instead of square).
In answer to your question: no you can't drop the pan with this in place. But there are two factors I considered when making it that way:
1) If you do allow to drop the pan then there is no protection for the tranny.
2) Any flange/removable setup under the tranny would be weaker than a single piece.
3) My tranny has a drain plug in the pan. I know it won't help with replacing the filter, but for basic maintenance, it's better than dropping the whole deal.
  #28
Private 1st Class
Post by bluesman2a on Jun 18, 2006, 9:36pm
Got everything bolted up this weekend and started in on a couple of other projects. Here are some shots of the finished product. Note: I added another hard-mount on the PTO cover cause I wanted everything supported in the cradle, didn't think the mounting plate on the 205 alone would handle it all.
  #29
fisherman's Avatar
Sergeant
fisherman is a Soldier
Default fisherman :
Post by fisherman on Jun 18, 2006, 11:53pm
Looking good, what are you planning to use for an e brake setup? I am right behind you on this. Just finished degreasing my np and will start mocking up a transfer crossmember. I am only using one t case though. I think I've figured out how I will do things just need to decide what to do for the e brake. Fisherman
  #30
Private 1st Class
Post by bluesman2a on Jun 19, 2006, 8:39am
I've got a Mico-Lock setup for the rear discs, and I'll use it as an advanced/mechanical line-lock like heavy equipment does. Once I get some things squared away I may change the rear calipers to Caddy Eldorados for the cable actuated e-brake.
HTML code is On
bluesman2a : Door Tech... bluesman2a PseudoZone - Stock Tech Archive 5 December 15th, 2009 12:04 PM
robertcowan : DOUBLER KIT QUESTION PseudoZone PseudoZone - Open Archive 13 November 12th, 2009 12:41 AM
bluesman2a : School me on FSJ doors? bluesman2a PseudoZone - Open Archive 4 November 11th, 2009 01:49 AM
bluesman2a : Let's talk tanks... bluesman2a PseudoZone - Open Archive 22 November 11th, 2009 01:34 AM
bluesman2a : New Lines... bluesman2a PseudoZone - Open Archive 7 November 11th, 2009 12:03 AM
1998 - 2019
Copyright 1998-2019
