Results 1 to 9 of 9
Thread: dummy : Wiring Schematic?
    Default dummy : Wiring Schematic?
    Wiring Schematic?
    Post by dummy on Jul 8, 2006, 6:57pm
    Trying to get my '68 M715 operational by next week. In other words, undoing all the bad stuff the previous owner hacked up.
    There are a number of wires dangling under the hood and inside the cab. The turn signal switch has been removed. Looks like it's the solid state one. Not sure what it originally went to. Also, can't get the brake lights to work either, but I haven't spent much time troubleshooting them yet. Is there a link to a wiring schematic that lists what the aluminum tags on the factory connectors correspond to? Here's what's dangling:
    Underhood -
    K- left rear turn signal
    E- right rear turn signal
    J - right front turn signal
    L- left front turn signal
    B- brake light signal from switch
    19-
    36-
    33-
    468-
    In cab -
    33-
    Anybody know what I'm looking at? In the past week I've basically had to install, replace, or rebuild everything except the transmission and the body. Need to get this thing going by 7/17 so I can drive it from LA to Colorado for Jp Mag.
    Thanks,
    Christian
    Default uscgmatt :
    Re: Wiring Schematic?
    Post by uscgmatt on Jul 8, 2006, 7:46pm
    Christian, here is a link to a page with all of the M-series circuit numbers. Hope this helps.
    http://www.olive-drab.com/od_mseries_circuits.php3
    Matt
    Default dummy :
    Post by dummy on Jul 8, 2006, 7:53pm
    Oh, man. That is perfect. Saves me a lot of time tracing.
    Thanks very much.
    Default k8icu :
    Post by k8icu on Jul 8, 2006, 8:55pm
    Also remember this one golden rule about MVs. GOOD GROUND!
    Make sure all your lights and circuts that have a ground side are grounded good. A zap with a sander or grinder to get bare metal, then a good external tooth lock washer, tighten up then a shot of paint to cover the bare metal will do wonders for your system.
    Default oilcan :
    Post by oilcan on Jul 9, 2006, 2:44am
    Lots of goodies in here, too.
    http://www.m715zone.com/manuals/
    Default brute4c :
    Post by brute4c on Jul 9, 2006, 8:17pm
    Yep good stuff in the manuals...this wiring page might help some...
    http://www.m715zone.com/manuals/wiri...lyharness.html
    Default dummy :
    Post by dummy on Jul 10, 2006, 8:05am
    Great links. All are very much appreciated. I've bookmarked the online manuals link. Very helpful. Gotta go to the office today, but tomorrow I'm gonna finish up the little stuff on the engine install and then get to the wiring.
    Default oilcan :
    Post by oilcan on Jul 10, 2006, 3:24pm
    Good luck!
    Default brute4c :
    Post by brute4c on Jul 10, 2006, 4:25pm
    Need more, just ask!!
  1. Dummy shaft
    By fishtail in forum Stock Tech
    Last Post: December 26th, 2009, 03:38 PM
  2. dummy : Running 12V AND 24V????
    Last Post: November 11th, 2009, 03:57 AM
  3. Dummy needs wiring help.
    By white433 in forum Modified Tech
    Last Post: February 25th, 2009, 10:47 PM
  4. Vent System Schematic
    By Roger1952 in forum Stock Tech
    Last Post: October 3rd, 2008, 08:40 AM
  5. CAD Wiring Schematic Created
    By rboltz in forum Stock Tech
    Last Post: March 21st, 2008, 11:44 PM
