Old December 15th, 2009, 05:00 PM
fisherman's Avatar
Sergeant
fisherman is a Soldier
Default fisherman : Receiver Hitch Finishished except paint
Post by fisherman on Oct 17, 2006, 12:02am
Started over the weekend mocking things up and figuring out how I wanted to do this. I did not ever want to worry about a weld breaking or a nut coming loose. I drilled and put in 6 9/16" grade 8 bolts 3 on each side, then fully welded and plated the back just in case. My spare tire xl when I get one will still fit nicely. I added a 90 grease fitting to the pintle hitch shaft lube point underneath so I can access the grease fitting with my needle adapter for my grease gun, as there is just enough clearance for it to fit in there and won't be coming out anytime soon. The clearance between receiver and pintle is close, but both still function fine. Maybe a little overkill, but one last modification almost finished. I will paint it sometime this week.
I used a receiver hitch from a wagoneer I bought for $50.00. I fully welded the two supports that go on the 45 degree angles in the back corners. On the wagoneer they were just bolted on, I thought fully welded would really strengthen the corners and rear crossmember. Fisherman
compexp's Avatar
compexp compexp is offline
Sergeant
compexp is a Soldier
Default compexp :
Re: Receiver Hitch Finishished except paint
Post by compexp on Oct 17, 2006, 12:56am
looks good!
Elwenil's Avatar
Elwenil Elwenil is offline
Private 1st Class
Elwenil is a Soldier
Default elwenil :
Post by elwenil on Oct 17, 2006, 7:18am
Looks freaking huge! Somebody resize that sheit!
fisherman's Avatar
Sergeant
Default fisherman :
Post by fisherman on Oct 17, 2006, 8:29am
I hit the hotlink for forums like I usually do, my camera just takes big pictures.
compexp's Avatar
Sergeant
Default compexp :
Post by compexp on Oct 17, 2006, 9:54am
Tim, it'd be ok, just need to put the pic links on different lines - they're all together now on one, which is making it wide.
Moderators - attend!
  #6
FSJGuy FSJGuy is offline
Private 1st Class
FSJGuy is a Soldier
Default fsjguy :
Post by fsjguy on Oct 17, 2006, 1:18pm
Looks good. I doubt that'll EVER come off, even if you WANTED to remove it!
HTML code is On
40grit : Receiver Hitch from RV( pics for Timmah) 40Grit PseudoZone - Open Archive 2 November 11th, 2009 01:24 AM
fisherman : Bedliner and Paint, Porkchop fisherman PseudoZone - Open Archive 5 November 10th, 2009 11:51 PM
Use for pintle hitch webstercj8 Open Discussion 14 April 11th, 2007 10:26 AM
hitch cnewman425 Open Discussion 17 February 26th, 2007 08:57 PM
1998 - 2019
Copyright 1998-2019
