Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: m715 front axle
  1. #11
    Quote Originally Posted by DaveA.
    No, I'm just saying that (pun intended) there was no need to reinvent the wheel when eight lug wheels had been used successfully by the big three for a number of years already. It is as if the head of Kaiser got the engineers together and said "Ok, the military wants a truck to use in the worst conditions possible. Our fighting men may depend on these trucks to save their lives. What say we sell them an engine that we have abandoned as unreliable even though we are currently using a much better one in our civvie trucks. While we are at it, let's use a transfer case that will overheat at the mind warping speed of 50mph.Screw the fact that there is a better one in production(np205). Oh yeah, before I forget let's give them a goofy lug pattern in the off chance these trucks end up in civilian hands so that future generations will bemoan the lack of cheap wheels and disc brake hardware.
    I don't think it is like that at all. I don't know what the big deal is with six, but have you ever noticed how many military vehicles used six lugs?
    Its not just Americans, either, because look at a unimog, six lugs.
    I think they use six because that allows the tires to be changed in the field that much quicker. Personally, I think load bearing is taken care of by using a large radius circle (7.25") instead of a small circle with a lot of lugs.
    I honestly think there is some reason to the six lug thing though, crazy as it may sound.
    Are you sure they had np205s in 1967? If so, how about 1966?
    I am sure, even if they were around at the time, they would have been more $$$, thus making it more cost effective to go np200 (you have other things to worry about going 50+ in a stock vehicle!); once the np200 was already in production, it was unneccessary to switch to a 205 when they became available.
    I always thought the stock engine was adequate, too. for its time, it was actually technologically advanced, being an OHC design. The six was also used in civilian vehicles for quite a while. I think people don't like it because it doesn't have hardened valves, and bigger tires or replacement of gears mean the engine no longer has enough leverage to move the behemoth.
  2. #12
    i read somewhere that the radius is dirctly proportional to strength. thats why we have WIDE 6 lugs.
    its all about money. ill wager it was cheaper for jeep to put the discontinued motor in the truck, along with the freaky axles. closed knuckle is purportedly stronger IN COMPARISON to similar designs. the closed knuckle design was replaced as people wanted disc brakes, and closed knuckles/disc brakes was not an easy or cheap engineering feat. open knuckles were cheaper to use/and adapt. thats what i was told by the helitool guys, who said they talked to some engineers from the time.
  3. #13
    There are trucks in the early 50's already that I know of that had our exact bolt pattern....there are probably older ones that have 6 bolt pattern...maybe even ours....never know it could be the precursor to the 8 bolt if you go back far enough...would have been easier to lay out for those in the presliderule days....
    As to being different....its a lifelong struggle.....you see I'm:
    6'6" tall
    left handed
    named Jon...with no "H"
    wear a size 15 EEEE shoe
    own an first year M715 and have a 2nd 67 frame to build up another
    cool but different nickname....brute force
    founded and run a super cool and free website for people even as wierd as b-
    How many people can say half of that......
    So I will keep my oddball bolt pattern....it suits me to a tee!!
    And if ya think it sucks so much.....why have one......some people like the ugly duckling....others just look and go away....
  4. #14
    NorthEast Texas
    Jon, I'm just saying that Kaiser had already discontinued the 230 by the time these trucks were produced. The 258 in my opinion would be a much better choice given the gear drive cam and iron head for the environment these trucks were meant to operate in. I will grant you that possibly the military had some input on the lug pattern. Please don't misunderstand me, I love these trucks as much as anyone but, there are some design snafus that make you wonder. I love chevrolets as well and there are some quirks there also. I guess my orig. point was that these had to have been designed by committee.
  5. #15
    I thought we were talking front axles.....
    On the motor....it has always intrigued me that the 230 was chosen...actually a redesigned 230 from the civvy one....both low production engines....Kaiser sure went to alot of work to use a vastly different 230 in this short production run....
    I can only conjecture that someone big at Kaiser was behind the 230 in a big way and in 64-65 when they were working up the specs for the M715 contract vehicle entry, the big wheel put a little weight on the 230 for the engine....maybe in an effort to have another platform to use to show up the engine...."It serves the military...it can serve you"....or something like that.....
    Remember, this is all theory....but what else makes sense??
  6. #16
    NorthEast Texas
    Speaking of (and getting further off subject) strange stuff, I have always thought that the vehicles in South America have some odd stuff. I saw a fuel injected 250-6 chevy engine on one website that was never available here.
  7. #17
    My daily ride is an '89 Range Rover. Land Rover always uses closed knuckles with cv type joints. They work very well and are very durable.
    My truck has nearly 200,000 miles on the drive train and the "swivels" are not the problem. Just change the oil yearly and no problems.
    Now the Lucas electricals...
    And by the way, the RR has 4 wheel discs.
  1. robertcowan : FRONT 8 LUG HUBS THAT FIT THE M715 FRONT AXLE
    Last Post: December 15th, 2009, 08:14 PM
  2. Need front axle measurement
    By scottsmyth in forum Stock Tech
    Last Post: September 19th, 2009, 06:10 PM
  3. front axle lubrication
    Last Post: November 13th, 2008, 05:35 PM
  4. Price on Front Axle
    By countcv61 in forum Open Discussion
    Last Post: June 9th, 2008, 07:56 PM
  5. Moding m715 front axle
    By 503m715 in forum Modified Tech
    Last Post: April 29th, 2008, 05:55 PM
