Results 1 to 2 of 2
Thread: tacomainoh : good 14bolt disc brackets, see post
    Default tacomainoh : good 14bolt disc brackets, see post
    Post by tacomainoh on Aug 6, 2006, 6:36am
    So here's some decent 14bolt disc brackets for those doing the swap.
    I personally prefer full-circle spacers or bent brackets instead of the common tube spacers. Anyway, here's a couple for you.
    From http://www.ruffstuffspecialties.com/...cket-p-10.html
    And these, from DIY4x, in northwestern IA of all places. These used to be available without the lightening holes, which is what I got, and I also got them with the 8-hole, full-circle spacer so I can move things around. Kert is a good guy to deal with and I got my stuff fast, with no hassles whatsoever. Also makes 14bolt yoke skidplates, and custom beadlocks.
    www.diy4x.com/brakes.htm
    anyway there's more out there, I just came across these pages this morning in my travels. Enjoy, hope it's useful.
    Atlanta, Ga.
    Default bluesman2a :
    Re: good 14bolt disc brackets, see post
    Post by bluesman2a on Aug 6, 2006, 12:38pm
    I agree with the spacer comment, I'm not much on the tube. One thing I might add here: I would go with the DIY setup before the other because it gives you more clocking positions. I wound up using the BTF brackets (DIY wasn't available when I bought mine), and it would have been a serious pain if I couldn't reclock them on a number of indexes (to clear the spring-packs).
    I'll also second dealing with DIY, they have some great product at reasonable prices and good service.
    BTF bracket link for s's and g's :
    http://www.bluetorchfab.com/oscomm/catal....&products_id=32
  1. Dana60 14bolt H1 hummer rims
    By Tomahawk715 in forum Modified Tech
    Last Post: November 29th, 2009, 09:01 AM
  2. tacomainoh : HYDRO STEERING MOD.
    Last Post: November 12th, 2009, 06:40 AM
  3. NP 205 brackets
    By phoenix in forum Modified Tech
    Last Post: December 16th, 2008, 09:47 AM
  4. Driveshaft mods w/14bolt ?
    Last Post: May 9th, 2008, 07:48 AM
