Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
Thread: bluesman2a : Doubler X-Member
  1. #31
    Washington State
    Default fisherman :
    Re: Doubler X-Member
    Post by fisherman on Jun 19, 2006, 9:52am
    What does the Mico-Lock setup entail? I have front discs stock axles, rear drums. A seventies duel master cylinder non power chevy master. I will be plumbing my own lines probably like you stated above. Looks to fun,, Fisherman
  2. #32
    Atlanta, Ga.
    Default bluesman2a :
    Post by bluesman2a on Jun 19, 2006, 11:47am
    A Mico-lock is what they used on a lot of heavy equipment back in the day. It's essentially a valve that mechanically maintains pressure on the calipers without any electrical input. Some of the cheapo linelocks have solenoids. With those, when you lose electrical, your e-brake cuts out.
    Part number 02-640-125 on page 3 from here:
    http://www.mico.com/litpdf/80-950-152.pdf
    The mico-lock supposes that you also have hydraulic pressure, so it's not a mechanical e-brake, but it's good for parking and the like. As such you have to plumb it in between your MC and the calipers. See pic of the control here in red:
  3. #33
    Washington State
    Default fisherman :
    Post by fisherman on Jun 19, 2006, 6:46pm
    Thanks that looks like it may be an easier install than swapping my driveline drum from the 200 over to the 205. Fisherman
  4. #34
    Default robertcowan :
    Post by robertcowan on Jun 19, 2006, 10:28pm
    if you want all 4 wheels brakeing and you have a split m/cyl. you need 2 of these.
  5. #35
    Default barrman :
    Post by barrman on Jun 20, 2006, 9:51am
    Doug has a lock on his brakes. He used it to full advantage at the FE. If you plan on getting stuck on the side of some hills, put one on.
  1. bluesman2a : Door Tech...
    By bluesman2a in forum PseudoZone - Stock Tech Archive
    Last Post: December 15th, 2009, 03:04 PM
  2. robertcowan : DOUBLER KIT QUESTION
    Last Post: November 12th, 2009, 03:41 AM
  3. bluesman2a : School me on FSJ doors?
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 04:49 AM
  4. bluesman2a : Let's talk tanks...
    Last Post: November 11th, 2009, 04:34 AM
  5. bluesman2a : New Lines...
    Last Post: November 11th, 2009, 03:03 AM
