Old April 4th, 2020, 06:58 PM
motorman605's Avatar
motorman605 motorman605 is offline
Civilian
motorman605 is a Soldier
Default insulating a M725
Good evening, say I was wondering if anyone stripped the interior of sheet metal to insulate the walls and cab area of a M725? It looks like a job, but up here in North Dakota it maybe worth it.
Old April 4th, 2020, 08:29 PM
glenn glenn is offline
Sergeant
glenn is a Soldier
This question should probably be moved to the modified or general forum. But as one who lives in the great white north and owns a M725 I would like to know too. I don't remember ever seeing anything on doing it.
I see you live in western ND. I worked in Dickinson for a year and Williston longer. Are you in the oilfield business?
Old April 5th, 2020, 08:55 AM
Nailhead's Avatar
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
Quote:
I just insulated the cab on my '72 IH pickup with 1/2" Dynaliner. It's self-adhesive closed-cell foam that would probably work pretty well for what your looking to do, but you're probably gonna need to own a few producing oil wells to pay for it-- it's pricey.
Old April 24th, 2020, 01:19 PM
Ambulance Driver's Avatar
Ambulance Driver Ambulance Driver is offline
New Recruit
Ambulance Driver is a Soldier
I have a member friend that removed the interior panels and insulated it with the pink rigid foam from HomeDepot or Lowes. Riveted the panels back on. Proper mastic should be used
Leave no soldier behind
Old May 7th, 2020, 09:45 AM
MJCougler's Avatar
MJCougler MJCougler is offline
Private 1st Class
MJCougler is a Soldier
My question and answer is this: is there any insulation in it at all from the factory? I have no way to tell on my M725 as I never have drilled out any of my rivets to look inside. I live in northern N.Y., and I learned that with a thin area to insulate, spray foam has a much higher R-value over fiberglass. But, it is a lot more expensive per cubic foot. And, not necessarily a DIY project. You should let the pros do it. That is how I insulated my summer place that has 2x4 wall construction.
Mike Cougler, MSgt, USAF Retired, '72-93
'67 M725, VIN 10030, Delivery: 7/67
Rochester, NY
  #6
Old May 8th, 2020, 07:06 AM
Nailhead's Avatar
Corporal
Quote:
If it's anything like an M43, it's insulated with fiberglass batting. The batting in my old M43 had broken down over the years and didn't feel all that effective, though.
Spray urethane might be a good choice, but you're right-- it would have to professionally applied because it has to be applied at a consistent & precise thickness to account for expansion. Over-application would create a world-class mess, I would think.
