Old April 30th, 2020, 04:39 PM
Bpmalo Bpmalo is offline
Civilian
Bpmalo is a Soldier
Default Front & Rear axles
Gang, I found an 83 Ford Ambulance with Dana 70 HD dually axles. 4.10 ratio.
Dana 60 with the dually adapters. I have read some posts and am still a little fuzzy on whether these are bolt no’s to the 68’ M715. $300 a piece from the local salvage yard. Yeah or nay? Thanks guys
Old April 30th, 2020, 04:42 PM
TXfirefighter is a Soldier
Go read the post on M715 zone...
Tons of info there.
The rear may bolt in. That front axle should be a spring over, so change’s will have to be made.
Just get a tape measure and start checking dimensions
Old April 30th, 2020, 04:47 PM
Civilian
Bpmalo is a Soldier
Good feedback. Thanks
Old April 30th, 2020, 04:50 PM
I used a dodge D-60 in rear. Had to relocate the spring perches. Used an F350 D-60 front axle. Was close to bolt in but, it’s spring over so I flipped the rear shackles to make it sit level.
Old April 30th, 2020, 05:03 PM
Civilian
Bpmalo is a Soldier
Shoot, my local yard have tons of those. I am very lucky, I have one of the best junk yards certainly in the Midwest 20 minutes from me. They have literally everything.
  #6
Old April 30th, 2020, 06:01 PM
glenn glenn is online now
Sergeant
glenn is a Soldier
That's pretty cheap for a Dana 60 front. The front should be fairly close to bolt in if you do a spring over. Rear might need disc brake conversion depending on how wide it is.
  #7
Old April 30th, 2020, 06:54 PM
Civilian
Bpmalo is a Soldier
Swinging by tomorrow and putting a tape on them. Thanks!
