Results 1 to 3 of 3
Thread: Fuel sending unit impedance
    Jan 2008
    Montreal Canada
    Default Fuel sending unit impedance
    What are the true ohms rating for the stock sending unit on a M715 ??
    I know that GM fuel gauges read 1 ohm @ Empty, 44 ohms @ Mid point, 88 ohms @ Full. What about the stock one ??
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
    The stock military fuel sending unit are not the same as any civilian ones.
    Empty 30 ohms
    Full 0 ohms
    This is OPPOSITE of the GM car senders used up to 1965 or so...
    If you were to use the older GM car sender, it would read full at empty and empty at full...
    Jan 2008
    Montreal Canada
    Thanks ... since i'm doing my 6bta swap ... i'll do as the same time all 12 volts gauges and bulbs. The sending unit is the only one that make me feel bad to changed ... so i will try to find something ....
    Thanks !!!
    M104A1 trailer
  1. 24v fuel sending unit
    By jrok93003 in forum Modified Tech
    Last Post: February 25th, 2010, 10:12 AM
  2. Stupid Fuel Sending Unit
    By fng in forum Stock Tech
    Last Post: November 17th, 2009, 10:28 PM
  3. maddawg308 : Fuel tank sending unit
    Last Post: November 12th, 2009, 06:43 AM
  4. Thermostat sending unit??
    By SouthernM715 in forum Stock Tech
    Last Post: November 12th, 2007, 04:11 PM
  5. Problem w/ Fuel Gauge or Sending Unit?
    By law in forum Stock Tech Archives
    Last Post: March 10th, 2004, 10:52 PM
