Results 1 to 3 of 3
Thread: Newby - Dumb Question-How do I remove air filter housing?
    Default Newby - Dumb Question-How do I remove air filter housing?
    Hello All,
    Thanks in advance for all the great information here. Dumb question from a newby. How do you remove the air filter housing from on top of the carb on a stock setup?
    Thanks!
    Silver Lake Sand Dunes MI
    Depends on which style it is. The 67's have a more standard style air cleaner that you just simply loosen the clamp on the bottom and lift it straight up. It's a long rod that sticks out just below the edge and the end is bent into a triangle. The 68'-69's that had the remote air cleaner, the air horn also has a clamp at the base you loosen.
    Dave
    Thanks Beast. That answered it for me. The handle was rusted pretty solid so I wasn't sure that was it.
