Results 1 to 7 of 7
Thread: damule : o.k. fellas what motor fits the best
    Default damule : o.k. fellas what motor fits the best
    Post by damule on Aug 16, 2006, 7:29pm
    I am going to have to do A swap.
    which motor can i fit the easyist. A chevy or ford
    do they make an adapter to fit about a 1972 ford 400 that will come out of a 4 door car my buddy says it has 400 right on the valve cover.Or should i go with A chevy, and if so , what type of vehicle from a junk yard should i try to find to when I go to get all the frames and brackets I need for the engines exterior components
    Any help will be appreciated
    sorry bout the spelling
    Mar 2004
    northern Arizona
    Default compexp :
    Re: o.k. fellas what motor fits the best
    Post by compexp on Aug 16, 2006, 7:35pm
    I used a chevy 350 with a novak adapter. If i did it again, I would find a fuel-injected chevy 350 and get the whole engine/tranny combo. Get the 2wd version and keep your NP200 xfer case, or get a 4wd version with a passenger side drop and re-do your driveshafts. An overdrive tranny such as the 700r4 really adds to the driveability.
    Guys have done everything from cummins 4bt turbo diesels to 501 caddy motors. Just about anything will fit with enough $$$, but the chevys are probably the cheapest to get parts for.
    Default tacomainoh :
    Post by tacomainoh on Aug 16, 2006, 7:52pm
    Chevy is cheaper/easier, mostly for parts interchange later.
    Grab everything. I recommend a post-87 350 w/TBI and a 700r4 or TH400 to go with it.
    Default mgmorrison :
    Post by mgmorrison on Aug 16, 2006, 9:10pm
    AMC's work good too...
    If you go with the Ford, you need a 2wd NP435 tranny.
    Auburn, AL
    Default snuffy :
    Post by snuffy on Aug 16, 2006, 9:46pm
    What do you want to do with the truck? There a pile of options, so choose the one that fits your purpose best. What are you keeping... what's expendable?
    Intercoolers on the diesels have been a problem. The Cummins 6BT - Bob Cowan has worked that one out, I think.
    Jan 2007
    Fort Smith, Arkansas
    Default wrecker :
    Post by wrecker on Aug 17, 2006, 11:24am
    Keep in mind, you'll likely be doing a tranny awap at the same time. The adapter for the chevy to the stock T-98 is available though. Not sure about any others.
    Post by tacomainoh on Aug 17, 2006, 11:34am
    also keep in mind: the Chevy to t98 adapter costs more than the 350/465 or 350/automatic usually costs.
  1. damule : brake shoe pad thickness?
    Last Post: November 11th, 2009, 11:21 PM
  2. Diesel Intercooler questions? What fits?
    By poolmike in forum Modified Tech
    Last Post: July 1st, 2009, 10:01 PM
  3. heater question, what fits?
    By Duane in forum Stock Tech
    Last Post: January 21st, 2009, 01:41 AM
  4. which rifle fits rifle holder
    By jpsnblood in forum Open Discussion
    Last Post: December 26th, 2008, 09:56 PM
  5. How to set the motor RPM
    By sf38a1 in forum Stock Tech
    Last Post: June 12th, 2008, 12:54 PM
