Results 1 to 10 of 10
Thread: Brake/tail lights flickering when headlights are on
    Dec 2017
    ARKANSAS CITY, ks
    Default Brake/tail lights flickering when headlights are on
    Need some help getting my stop/turn lights to work correctly. When I'm in service drive (first click on three way switch) the brake and turn signal work fine. When I turn it to the second click and turn on the headlights, the front and rear marker/turn lights both will blink when using the turn signal or brakes. I have replaced with new parts the rear lights and both turn signal switch and controller. I replaced the wiring harness between the switch and controller with a used one that I had along with trying two different used 3 way stitches that I had. Wiring along the frame appears to be intact. I did have to repair the rear wiring for the lights at the end of the frame so that all should be good. I'm assuming I have a short to ground somewhere, but I have had no luck finding it.
    Sent from my SM-G930P using Tapatalk
    bad ground most likely on the head light system
    Could also be a weak alternator. Check your voltage with and without headlights on. You should be getting at least 28V when charging properly.
    Dec 2017
    ARKANSAS CITY, ks
    Headlights is the only thing I havnt really looked at. I added new star washers to all four signal lights. I'll look at the headlights this weekend.
    Quote Originally Posted by tomb View Post
    Dec 2017
    ARKANSAS CITY, ks
    Quote Originally Posted by kwai View Post
    I never even thought to check that. My alternator is covered in oil from a leaking power steering pump. I could see where that could cause it to deteriorate a little.
    If that all checks out then you are left with the 3 lever switch or under dash wiring shorts. Those are always fun.
    Jan 2011
    Fernandina Beach, FL
    If I remember correctly, there is a circuit breaker inside of the three-lever switch. That might be weak or you may have a pinched or corroded wire somewhere.
    Just a thought...
    Dec 2017
    ARKANSAS CITY, ks
    That switch wasn't easy to get out for a fat guy. Lol
    Dec 2017
    ARKANSAS CITY, ks
    Just a thought...
    That could be why I had 2 spares in a box of parts that I bought. Any way to bench test it? Didn't really see anything in the manual for it.
    At the top of the page is a link to maintenance manuals. One of those is called the M715 lighting diagram. Print it out. It is the best pin out for the 3 lever and turn signal switch I have found yet.
    I have the best success with a DVOM that has the beeper on the Ohm setting. Just set the meter to the beeper, put a lad in the power in pin and the as you move the levers to different functions. Put the other lead in the appropriate pin. If it beeps all is good.
    That checks basic functionality of the switch. Not the breaker inside the switch. I have no idea how to Amp check it. Sorry.
