Results 1 to 3 of 3
Thread: Tranny help
    Mar 2004
    northern Arizona
    Heeelllllpp! How do I differentiate between a T-18 and T-98 tranny? I have a 10-spline shaft from the tranny, so I'm assuming T-18. Is this correct?
    Need a bellhousing to fit. Was told Jeep bellhousing that fits 3-speed will also fit.
    Thanks!
    Rich Holley
    67 m725
    79 j10 (x2)
    Default Tranny help
    The t98 is a 10 spline...so no luck there...the only difference I know of is the bolt pattern on the front of the trans...t18 has even spacing between the upper and lower bolts on both sides...the t98 has the bolts closer together, very obvious visually, on one side and spaced wider like the t18 on the other.
    Hope that helps.
    New Haven, CT
    All T18 and T98's I've had laying around, had either "T18" or "T98" cast on the shift tower. Easy enough
    Bellhousings should be identical. Just make sure you get one with the correct input shaft lenght (6cyl input shafts are shorter than V8 trannies).
  1. Tranny fluid
    Last Post: March 11th, 2009, 08:17 AM
  2. 727 4x4 tranny
    By scottsmyth in forum Modified Tech
    Last Post: November 20th, 2008, 03:50 PM
  3. Tranny help - Again!
    By compexp in forum Stock Tech Archives
    Last Post: April 13th, 2004, 03:37 PM
  4. Automatic Tranny
    By Nuke_nitewolf0s in forum Modified Tech Archives
    Last Post: January 22nd, 2004, 07:01 PM
