Results 1 to 6 of 6
Thread: shackles
    Default shackles
    I know I asked this before on the pseudo zone. One of our fine members over here used lifted cherokee shackles for their rig. I searched here via google and on the pzone. I'm asking because I remember they had to be drilled out a little to fit, and I'm picking up a set on Thursday. What exactly was the mod?- gonz
    that was me..... hang on ... let me find the teck because I don't remember.... I still have them on the rig if I need to look at what I did tho...
    edit: the front bolted right up.... it was the back that I modded...
    Money!! I'm picking them up tonight in Cheyenne- gonz
    Aaron871- Thanks again!
    I found the pic's but can't find the thread....
    Found my winch bumper pic's too...
    OK....
    in the rear, at the frame you have to drill out the shackle bushing to 5/8's
    in the rear, at the spring you can either drill the holes in the shackle bigger or (what I did) replace the spring bushing with a bushing from a 1975 CJ-5 spring bushing. And use a smaller bolt.
    Good luck and post some pic's.....
  1. Stock Shackles
    By Dustbuster in forum Stock Tech
    Last Post: July 8th, 2009, 10:42 AM
  2. tow shackles
    By 14fan in forum Open Discussion
    Last Post: May 5th, 2009, 04:28 PM
  3. Lifting Shackles too narrow
    By Cornholio in forum Stock Tech
    Last Post: November 21st, 2007, 07:55 AM
  4. front shackles
    By Gwen in forum Open Discussion
    Last Post: January 9th, 2007, 10:30 AM
  5. Spring over rear shackles
    By fisherman in forum Modified Tech Archives
    Last Post: April 8th, 2004, 10:18 AM
