Old November 10th, 2009, 08:26 PM
Moderator
PseudoZone is a Soldier
Default mikec3820 : need to know wheel bearings
Post by mikec3820 on Apr 10, 2006, 5:12pm
Do any of you fine folk know what size the nuts holding the wheel hub on the spindle (front passenger) are so I can get a socket to fit them. Also, My bearings are fried and I am not sure of a part #. Anybody know if the local parts house would have them.
LuckyPabst's Avatar
LuckyPabst LuckyPabst is offline
Private 1st Class
LuckyPabst is a Soldier
Default luckypabst :
Re: need to know wheel bearings
Post by luckypabst on Apr 10, 2006, 7:14pm
I thought I had the bearing and race numbers in my notes but I guess not. They are common parts, just take in the number off the bearing and the number from the race.
Front wheel grease seals are Nat'l #475384, about $20 each.
I wanna say the nut is 2-9/16". Best to measure yours if nobody chimes in.
Chris
Moderator
Default mikec3820 :
Post by mikec3820 on Apr 11, 2006, 5:37am
Thank you. I'll try to get a part number off the bearings, but one of them completely desentigrated going down the road.
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Post by brute4c on Apr 11, 2006, 9:06am
I think these are correct...
Outer-Timken #18790 Rated @2950 lbs.
Cup #18720
Inner-Timken #387A Rated @4900 lbs.
Cup #382A
Moderator
Default mikec3820 :
Post by mikec3820 on Apr 11, 2006, 7:52pm
Thank you. I'll call right now and see if they are in stock here. I suppose i will disect the front spindle and hub this weekend.
  #6
brute4c's Avatar
Grand Poobah
Default brute4c :
Post by brute4c on Apr 11, 2006, 9:50pm
I have a hub socket...its iss 2 9/16ths inch...
HTML code is On
230 rod bearings SR. Modified Tech 6 March 12th, 2010 12:32 AM
uscgmatt : Rear axle wheel bearings. PseudoZone PseudoZone - Open Archive 9 November 10th, 2009 09:02 PM
Connecting Rod Bearings rboltz Stock Tech 7 February 11th, 2009 11:29 PM
NAPA part numbers for front and rear wheel bearings? maddawg308 Open Discussion 13 January 5th, 2008 08:33 AM
rear wheel bearings terryb Stock Tech 2 March 6th, 2007 04:20 AM
1998 - 2019
Copyright 1998-2019
