Results 1 to 7 of 7
Thread: barrman : 24 Volt Welding
    Default barrman : 24 Volt Welding
    24 Volt Welding
    Post by barrman on Oct 16, 2006, 2:52pm
    This came up at the Texas FE as a possible fix for Koobsters sector shaft. What rods has anybody used successfully to weld with 24V? I figured I should add some to my tool box once I know what works.
    Thanks.
    Default oilcan :
    Re: 24 Volt Welding
    Post by oilcan on Oct 16, 2006, 10:55pm
    There was an article in Jp about this a few months back. Going from my horrendous memory, I think 6014 worked the best. Something about 24v being too weak for 7018 rod, and 36v was too much.
    Crap, now I gotta go try to find it.
    Default gimpyrobb :
    Re: 24 Volt Welding
    Post by gimpyrobb on Oct 16, 2006, 11:30pm
    I thought it was (more)currant that did the job, not (less) voltage?
    Default oilcan :
    Re: 24 Volt Welding
    Post by oilcan on Oct 16, 2006, 11:43pm
    Fudge, I don't know!
    I did try it once with 7018, and got a bead run. It looked like dooky, but it worked.
    Default nc715 :
    Re: 24 Volt Welding
    Post by nc715 on Oct 17, 2006, 1:07am
    You are right, the amperage is what affects the weld, not the voltage. The short circuit voltage of most welding machines is generally about 28 volts as I remember.
    I would recomend using 6013. I am not familiar with 6014 so I can not comment.
    7018 is a low hydrogen rod and needs to be stored in low humidity conditions.
    Default gimpyrobb :
    Re: 24 Volt Welding
    Post by gimpyrobb on Oct 17, 2006, 8:04am
    Well I was reading on the ready welder and it does sheet with 12v, up to 1/2inch at 24v, and up to 3/4 at 36v. I guess it comes into play more than I thought, but 3/4 inch!?
    Auburn, AL
    Default snuffy :
    Re: 24 Volt Welding
    Post by snuffy on Oct 17, 2006, 5:27pm
    Lookee here...
    http://www.premierpowerwelder.com/re...readyweld.html
    I'm inclined to say the 6013 as well, but DC is wrecking my confidence about it.
  1. Welding on a M715
    Last Post: May 21st, 2008, 10:18 PM
  2. 12 volt tach, 24 volt system
    Last Post: May 19th, 2008, 03:12 PM
  3. Welding tip of the day
    Last Post: April 30th, 2008, 10:14 PM
  4. welding spiders
    By 5quarter in forum Modified Tech
    Last Post: May 24th, 2007, 07:45 AM
