Forums | Basic Training | Online Maintenance Manuals | The M715 Zone Vin Registry | VPW's M715 Parts List | Galleries | Links |
Modified Tech Tech forums for Modified M715 series vehicles |
Thread Tools | Display Modes |
#1
What are the best wheels in your experience for pavement, gravel, dirt roads... grassy hills... NOT mud bogs or boulder climbing. I prefer to stay close to the original look of the wheels… That military industrial look if possible. I’m changing out axles so I may not be able to use the stock wheels.
Last edited by Okie5; February 1st, 2021 at 02:39 PM. Reason: Spelling challenged |
#2
If you mean tires and not wheels, then STA Super Traxion tires are what you are looking for.
#3
![]() Quote:
That said tire advice is much appreciated as well! 😀 |
#4
Regular ol' steel wheels. Wagon wheels. Tough, cheap, good on and off road. If you are changing out axles then make sure you get a standard GM 8 bolt pattern. You'll NEVER run out of wheels to pick from. I run hummer wheels w/ run flat inserts for double bead lock on mine.
Tags |
classic, off road, wheels |
Thread Tools | |
Display Modes | |
