Old February 1st, 2021, 02:35 PM
Okie5 Okie5 is offline
Civilian
Okie5 is a Soldier
Default Best wheels - street and off road
What are the best wheels in your experience for pavement, gravel, dirt roads... grassy hills... NOT mud bogs or boulder climbing. I prefer to stay close to the original look of the wheels… That military industrial look if possible. I’m changing out axles so I may not be able to use the stock wheels.
Old February 1st, 2021, 04:23 PM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
If you mean tires and not wheels, then STA Super Traxion tires are what you are looking for.
Old February 2nd, 2021, 07:56 AM
Civilian
Okie5 is a Soldier
Quote:
I mean wheels because I don’t need pretty wheels or titanium indestructible wheels.
That said tire advice is much appreciated as well! 😀
Old February 2nd, 2021, 03:06 PM
teking teking is offline
Corporal
teking is a Soldier
Regular ol' steel wheels. Wagon wheels. Tough, cheap, good on and off road. If you are changing out axles then make sure you get a standard GM 8 bolt pattern. You'll NEVER run out of wheels to pick from. I run hummer wheels w/ run flat inserts for double bead lock on mine.
Tags
classic, off road, wheels
1998 - 2021
Copyright 1998-2021
