Results 1 to 5 of 5
Thread: Spare tire
    Geneva, FL
    Blog Entries
    1
    Default Spare tire
    Question what's the largest size tire you guys have been able to fit in the stock spare tire location with the stock securing bar?
    Sent from my SM-G930V using Tapatalk
    If I recall, 36". Fisherman moved the support bar in the frame to make more room and was able to put in a 38" tire. This is from memory.
    Found his post on it It's tucked, my spare that is.
    All the pictures are broken links now, unfortunately.
    Come and take it
    Geneva, FL
    Blog Entries
    1
    Quote Originally Posted by gonz View Post
    Thx man
    Feb 2004
    Silver Lake Sand Dunes MI
    I have a 36x12-16 swamper that matches the tires on my truck up in the stock location. I had to deflate the tire a bit to get it up in there and once bolted in re-inflate the tire. It's wedged up in there tight. If I ever needed it I'm going to need an air source as I'll have to more than likely let the air out to get it back down and out.
    Dave
    New Haven, CT
    I moved that crossmember too and I carry a 37" spare there. I mounted a strap winch (from a tractor trailer) and a pulley so I can winch the wheel into place using a 1/2" ratchet.
