Results 1 to 6 of 6
Thread: Wiper Filters
    My stock vacuum wipers stopped working the other day. Not a big problem since my top is off and I try not to drive it on days when rain is forcast. I determined that I had plenty of vacuum and that my on/off valve was working. I next took apart my motors. The problem was the air inlet nozzles. They were full of some kind of packing and bugs. I just cleaned them all the way out and reinstalled them. They now work great. Is there some kind of filter type thing supposed to be packed in the inlets? And how much damage can be done if I don't put anything back in? The only trouble I can forsee is more bugs or critters getting in side again. I don't think enough dirt and grit will get sucked all the way thtough the system to cause vacuum pump failure. I don't know, so that is why I am asking. Thanks.
    Default Wiper Filters
    I've never heard of such a thing...though it makes perfect sense...maybe a little snip from an old nylon with a zip tie?
    Be cheap and easy to remove...
    Hey thats funny,
    the same thing thing happened to me. My wipers quite working. I opened them up, and found wasp cocoons in both wiper housings. They were both dead, grew too big inside. Seems to happen to me at least twice a year. I don't know why they like the inside of that thing.
    The packing reminded me of a cigarette filter. I was thinking of the nylon/zip tie combo myself.
    West-central Ohio
    Default Gas fired heater owners
    section of pipe cleaner. Easy to remove/clean or replace... You can get ocer-sized ones at craft stores...
    you are overthinking this.
    Spiders love to live in vacume lines. I have to clean mine out every few years to keep them working. (m151). I think I might try the old stockin/zip tie trick too.
    Zone holster maker
  1. wiper trouble
    By alex in forum Modified Tech
    Last Post: April 30th, 2009, 07:55 AM
  2. help blowing off oil filters
    By fireman in forum Open Discussion
    Last Post: April 17th, 2008, 04:11 PM
  3. Wiper motor
    By Kamikaze12volts in forum Stock Tech
    Last Post: March 17th, 2008, 03:55 PM
  4. M725 blowing off oil filters!
    Last Post: September 20th, 2007, 10:46 AM
  5. Wiper Blades
    Last Post: December 24th, 2006, 04:12 PM
