How can I mount another generator, so I can have 12v to my plow. Pictures please.
Dan
Dan
What type of engine? Stock, modified? Being that you posted in the stock forum, I figure you must have a 230.
You will most likely have to fab up any brackets to do the job... As long as there is space for it and belt alignment isn't an issue, it shouldn't be too hard to do. An alternator may be a better choice for that application too.
Moved this to the Modified forum, since it's a question about a modification from stock.
You're pretty much going to have to fabricate your own brackets, I think. You mounting a separate 12V battery too, to run the 12V gear? I'm assuming here you're still 24V otherwise, eh?
-- Tim Taylor
