Page 9 of 13 FirstFirst 12345678910111213 LastLast
Results 81 to 90 of 123
Thread: M715 Hauler / Crawler Build
  1. #81
    Might bug you potentially for that solidworks frame assembly....
    Will be doing Cummins 6BT motor mounts soon enough.... I have a 12 valve already 3D modeled... but I do NOT have the frame done up yet.... We'll see if your willing to "borrow" it out. (I'm on Solidworks 2014 so I should be able to take anything at that point or earlier.) Would be nice to do all of the motors mounts in 3D CAD and go right to the waterjet
    (Mech. Engineer for a living)
  2. #82
    Send over your email via PM, I would be glad to share.
  3. #83
    I rolled across the scales at 5360 lbs. That was with 12 gallons of gas, a full size spare and not counting my weight. I also picked a Gladiator grille and side covers.
  4. #84
    The radiator, fan and shroud setup couldn’t keep the big block cool in the summer heat. It was overheating at idle and at speed. After some rearranging, I dropped in a larger radiator, dual fans and a home-made shroud. Temps are under control now, we’ll see how it holds up when the summer rolls around.
  5. #85
    looks good
  7. #87
    Sep 2014
    Wichita Falls, TX
    Sharp truck man.
  8. #88
    Thanks again for all the help Kaiser715!
  9. #89
    Got some 40s! Goodyear MTRs.
  10. #90
    Looks better with those new tires. Not that it looked bad before.
