  #11
Old May 21st, 2011, 08:44 PM
MJCougler's Avatar
MJCougler MJCougler is offline
Private 1st Class
MJCougler is a Soldier
Default Fuel Filter at the tank.
Now that my truck is running, I'm beginning to drive my truck around the neighborhood. This way, if it quits on me I can easily walk home to get my CTD tow vehicle. I drove it initially to get 2/3s a tank of gas, and I have driven only about five miles or less since I got it started. Already, the see-through fuel filter I installed where the rubber hose comes from the tank is half filled with a brownish mud-looking sludge. The fuel filter at the carb is just brown from the fuel. Engine runs rough still. I need to adjust the mixture and the timing, but I'm waiting for my new/used Snap-on timing light.
my$.02
Mike Cougler, MSgt, USAF Retired, '72-93
'67 M725, VIN 10030, Delivery: 7/67
Rochester, NY
  #12
Old May 22nd, 2011, 07:56 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Quote:
Originally Posted by MJCougler View Post
Now that my truck is running, ... Already, the see-through fuel filter I installed where the rubber hose comes from the tank is half filled with a brownish mud-looking sludge. The fuel filter at the carb is just brown from the fuel. Engine runs rough still. ...
my$.02
I think that you have found the problem: contaminated fuel. If it is from a rusty tank, you may need to deal with that or replace the tank. I am sure you don't want to hear that (I didn't!) but that to me seems to be the root of the problem.
My carburetor was filled with powdered rust. I rebuilt it and didn't want to fill it up again with rust. So I bit the bullet, spent money I didn't have and ordered a new tank from Mike. Last week, I replaced the fuel line from the tank to the rubber hose at the engine. I removed the steel line from the rubber hose to the fuel pump and it was clean and no rust. I removed the flared end from the engine fuel line and crimped a "barb" on it. Then, I used plain old 5/16" rubber fuel line to connect the two hoses. Still waiting on the tank to attempt a first start...
  #13
Old May 29th, 2011, 09:38 PM
MJCougler's Avatar
Private 1st Class
Default the correct carb gasket?
DON; Anyone?
I may have another problem besides contaminated fuel. Yes, the truck idles rough. But, I am also wondering about the two-notch gasket I installed under the carburator.
The instructions that I downloaded from the Holley website states the two notches go toward the idle screw side of the carb. But, I read a post or stickey recently that said I need the four-notch gasket. And, the parts manual shows a carb gasket that does not have any notches. Which is correct?
I mounted the 2-notch gasket with the notches toward the idle screw (toward the valve cover side). It idles rough. I do need to adjust the timing, but the question still remains, anyone have the page that describes the correct carb gasket?
Yes, I have dirty fuel, but do I also have the wrong carb gasket?
Thanks again team,
Rochester, NY
  #14
Old May 30th, 2011, 06:39 AM
Don Cavey's Avatar
Staff Sergeant
Mike, I am not sure about the gasket. But if you have had and maybe still do have dirty fuel, maybe the carburetor and main jet are gummy or clogged again. If you have another bowl gasket, you may be able to take the bowl off while the carburetor is still on the manifold and spray out any contamination with something like Berkebile 2+2 Gum Cutter. That stuff works well for me (Not nearly as good as it was in the early 70s.)
I looked at the exploded picture in the 34P manual and it shows two cut-outs facing the engine. But sometimes, these illustrations are approximate and not to be taken literally. I know it is frustrating.
(A little OT) I may be able to start mine today for the first time. I don't have the new fuel tank today. But I have just about corrected all of the "modifications" to the original wiring. My intention is to strap a 5 gal Jerry can into the holder on the driver side and put a 5/16 rubber hose from the fuel line to inside of the can. Wish me luck!
  #15
Old May 30th, 2011, 06:47 AM
Don Cavey's Avatar
Staff Sergeant
Check this out:
And for what it is worth, my carburetor is missing #76 the baffle. I also found out the jet number in my carb is #692. Hope that is original.
BTW, my reference to the manual above is incorrect. It is actually the -34 manual, not the -34P as I stated. Sorry for that "Senior Moment". They seem to be more frequent as life goes on.
  #16
Old August 7th, 2019, 03:24 PM
old dog old dog is offline
old dog is a Soldier
having a problem with my truck today, all stock and have a spare parts on pallet racking......no gas to carb at all, took off line to fuel filter which is after fuel pump and cranked truck and no fuel.........b4 i switch out my fuel pump any thing else to try??? thanks for any help...........
  #17
Old August 8th, 2019, 08:29 PM
kwai's Avatar
kwai kwai is online now
Sergeant
kwai is a Soldier
no fuel = bad pump (or plugged line at tank).
I would change the pump, blow the line out back into the tank. change filter.
Also, you can disconnect the short line from the frame rail to the engine and feed in fuel from a 5 gal can strapped to the front bumper. I do this to test the pump and get trucks running all the time.
  #18
Old August 10th, 2019, 08:59 AM
Nailhead's Avatar
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
Quote:
Originally Posted by Don Cavey View Post
Since my carburetor had rust in it and the tank is a mess, I have decided to buy a new SS tank from Mike and replace the fuel lines from the tank to the engine. They are easy to get at and not made of anything exotic. I have a double flare and tube bender so with all new parts, I hope to be ahead of the game. I will most likely replace the still original rubber fuel line that goes from the frame to the engine with conventional rubber fuel line. I also intend to use high pressure fuel line designed for fuel injection and high pressure clamps. Yes, it costs more but I hope to only do this one time.
I will let you know how it goes. I just can't see taking the time to rebuild the carburetor (I already did) and then just pump rust into it again. I am undecided as to whether I will put another filter at the tank. I think that using a new tank will eliminate that issue.
Pix of the carb before rebuild and the "nasty" tank.
I fought a rusty tank the whole time I owned my Hercules M37 because I wasn't smart enough to have it cleaned out, or even buy an NOS replacement. Removing & cleaning the filter element from a Bendix-type interruptor pump by the side of the road at night was typical and hateful.
  #19
Old August 11th, 2019, 12:50 PM
thanks much, never thought of that, once drove a old jeep home with a 5 gallon can strapped to the roof!!!
  #20
Old August 11th, 2019, 04:58 PM
Don Cavey's Avatar
Staff Sergeant
This what I did when I was waiting for my new stainless steel tank. I refused to be bothered with a rusty tank. They come back to haunt you.
Trouble with this was that when I drove around the yard, the gas sloshed out of the can!
1998 - 2019
Copyright 1998-2019
