Old July 27th, 2019, 06:25 AM
ziky ziky is offline
New Recruit
ziky is a Soldier
Default m715 suspension -coil spring +rod
hello
I want to change the m715 suspension from lef to coil sring+rod where can I buy a full kit
thank you
ziky
Old July 27th, 2019, 09:44 AM
jhartings is a Soldier
I donít think there is a kit. Would need to fabricate it yourself. There was a post on here where someone took a Ford F-250 and cut the suspension off to resell it on a M715 but donít think they posted final product.
Old July 27th, 2019, 09:47 AM
The post was by Grendel back in May. Just search for F250.
Old July 27th, 2019, 03:13 PM
glenn glenn is offline
Sergeant
glenn is a Soldier
Alosix did a frontend conversion using coil spring Dodge axle and parts on here. Not a whole lot of info but he does give some.
Old July 28th, 2019, 07:38 AM
Grendel Grendel is offline
Basic Trainee
Grendel is a Soldier
WFO and Ruffstuff both have a radius arm kit that will put a 2005 F250+ front axle into another truck.
That's about as kit as you're going to get. To be clear, there is still alot of figuring and fabrication to do.
Me, I want to use all stock parts, so I grabbed an F350 frame to rob all the parts from.
1998 - 2019
Copyright 1998-2019
