Go Back   M715 Zone > General Tech > Stock Tech > PseudoZone - Stock Tech Archive
Old December 15th, 2009, 01:01 PM
Moderator
PseudoZone is a Soldier
Default xjchief : Exhaust Manifold and system
Post by xjchief on Sept 30, 2006, 4:25pm
Finally got most of the parts together to replace the stock exhaust from the block back. I've removed half the pipe but am stalled on the manifold. The studs are all backing out instead of the nuts on the studs. I've never replaced one of these before so I was wondering if this is okay of if I need to replace the studs and the nuts now. Also, any suggestions regarding antisieze or lock tight?
Like I said, never done this before and don't want to mess it up.
Thanks for the help.
XJ
Moderator
Default koobster :
Re: Exhaust Manifold and system
Post by koobster on Sept 30, 2006, 4:30pm
so did mine this morning 2 of the studs stayed in. When U put them back in just make sure they are tight
Moderator
Default xjchief :
Post by xjchief on Oct 1, 2006, 10:35am
Okay, I'd like to replace the studs. They look pretty bad. A trip to Napa, Advanced, Autozone, leaves me empty handed. Does someone know where I can get a set?
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Default brute4c :
Post by brute4c on Oct 1, 2006, 2:29pm
Hmmm...I took a long and ashort one to Napa and got all that I needed...they arent too oddball...
Moderator
Default xjchief :
Post by xjchief on Oct 1, 2006, 5:46pm
Ace Hardware had some that are almost an exact replacement.
HTML code is On
xjchief : Exhaust Fanges PseudoZone PseudoZone - Stock Tech Archive 3 December 15th, 2009 01:15 PM
How to prevent a cracked exhaust manifold brute4c Stock Tech 28 February 22nd, 2009 09:37 PM
Cracked exhaust manifold, etc. Beachtruck Stock Tech 3 June 24th, 2008 03:17 PM
Dorman exhaust manifold chicklin Stock Tech 2 June 12th, 2008 07:49 AM
Exhaust manifold replacement ?? viperman Open Discussion 6 April 17th, 2008 12:26 AM
1998 - 2021
Copyright 1998-2021
