Results 1 to 5 of 5
Thread: Steering column spring?????
    Apr 2014
    Jacksonville, NC
    Default Steering column spring?????
    I've read the steering sections in the 20 & 34 maintenance manuals. I just don't understand the spring behind the steering wheel. I'm installing 2 u-joints and don't know if the spring should be compressed or not before i mark my steering shaft and cut it to fit the u-joint. The spring will compress a good 3 inches, but doing that doesn't make sense to me. Or am I doing this wrong? Thanks.
    Boy....good question and I wish I knew the answer...hopefully Barrman sees this...I think he will know...
    When I did mine I marked and cut the shaft before I took it apart. Let me go look in my garage at it today and get back to you.
    Apr 2014
    Jacksonville, NC
    At first i thought the purpose of the spring was to provide a ground for the horn button.
    Apr 2014
    Jacksonville, NC
Tags for this Thread
