Results 1 to 10 of 10
Thread: tngreenmachine : Chevy dana 70 rear
    Default tngreenmachine : Chevy dana 70 rear
    Chevy dana 70 rear
    Post by tngreenmachine on Oct 10, 2006, 6:46pm
    Is there anything easier/ better about swapping in a chevy dana 70 rather than the 14 bolt?
    Also there used to be a write up or two about swaping in a dana 44 8 lug axle into the front and I was thinking bout doing that until I could spring for the chevy 60. If anyone has a link that would be sweet.
    Default davea :
    Re: Chevy dana 70 rear
    Post by davea on Oct 11, 2006, 11:06am
    the d-70 rear may be too wide as it was installed in dually trucks with factory pickup beds only. the cab and chassis one tons with dual rears got 14 bolt rears that are more narrow than a single wheel 14 bolt.
    Default bigwheelbob :
    Post by bigwheelbob on Oct 11, 2006, 12:23pm
    This is not entirely correct. The dana 70 could have been had in lots of single wheel trucks. Older F-350's, newer Dodges, and more. The width of the single wheel dana 70's should be fine for our trucks.
    Jan 2007
    Fort Smith, Arkansas
    Default wrecker :
    Post by wrecker on Oct 11, 2006, 2:42pm
    The brake drum interferance with the required spring location issue might not apply to the wider axle also. Just a thought.
    Post by tngreenmachine on Oct 11, 2006, 5:01pm
    The width on this one is 67.5 but it has much narrower drums than a 14bolt.
    Default over2land :
    Post by over2land on Oct 11, 2006, 11:00pm
    What's WMS to WMS of stock?
    I thought it was more than that...
    Post by bigwheelbob on Oct 12, 2006, 6:55am
    This is a very good point! And the 14 bolt uses atleast 3 different sizes of brake shoes. I have always felt a 14 bolt out of a van would be the perfect rear for tha 715 because of the 3 inches extra width.
    Default over2land :
    Post by over2land on Oct 12, 2006, 8:19am
    Frapguy used a 70 out of an early 70's Ford 15- passenger van.
    I've got all the info written down at home, year, width and so on if anyone is interested.
    However, I won't be home until Monday... so hope you aren't tooo interested.
    Post by bigwheelbob on Oct 12, 2006, 12:12pm
    If you use one out of a dodge, or some ford vans, you will also get the driveshaft out of the gas tank. Slightly offset.
    Default davea :
    Post by davea on Oct 13, 2006, 4:47pm
    BWB, I knew other companies offered a single wheel version, but he asked about the chevy version.
  1. chevy dana 60 & 44" boggers
    By Agent Orange in forum Modified Tech
    Last Post: September 19th, 2009, 02:47 AM
  2. Brake lines -Dana 60 chevy
    By Tomahawk715 in forum Modified Tech
    Last Post: March 29th, 2009, 08:49 PM
  3. will chevy dana 60 hubs & rotors fit?
    By Prime Time Customs in forum Modified Tech
    Last Post: September 18th, 2007, 09:28 AM
