I just won a 726? over at the OK Forestry auction, already converted to a V6 and power steering! It started out life as a 6217 contact maint. truck, it now has a cut on standard bed. After a little tinkering it started right up, the power steering does some squealing near the stops but other than that a pretty fair little truck. I was bleeding the brakes and noticed the pto setup, I had assumed it has a pto with two shafts front and rear but the way it is set up is a pto on the transmission for the front winch and a pto on the transfer case for the genset/welder that was in the maint. box! Now I am thinking what I can do with that rear facing pto, rear winch, hydraulic pump?
James
