Page 14 of 23 FirstFirst ... 4567891011121314151617181920212223 LastLast
Results 131 to 140 of 227
Thread: Finally got her on the road!
  1. #131
    Sep 2010
    Middleville, mi.
    I try to do little bites myself. I have had a tendency to bite off more than I can chew in the past.
    I also get distracted quickly.
    I've got a 6.2 that I am planning on swapping in. I decided I would get it on my engine stand and fire it up to hear it run before I go through the trouble of extracting the old 305 gasser.
    While it is on the stand I decided I might as well pull the pan and check the webs before I filled it full of new oil.
    That led to degreasing and sanding down the oil pan and giving it a coat of paint.
    Then the valve covers looked out of place because they didn't match...
    Now I'm thinking I may as well wait until I get some tires from George before I pull the old engine because I want to drive my truck to see if it still vibrates at 48 MPH once I have some better tires.
    Eventually I may be done too.?!
  2. #132
    Nov 2009
    Greenwood, Indiana
    I'm with you bro. I'm the king of getting side tracked while working on something. You see something else that you should do "while you are at it".
    I dont have any vibrations at my top end of 43-45mph
    Hopefully you guys dont get a big dump of snow tomorrow. So far, along I-80, it has been little snow, but lots of wind
    Thanks, George
    Joshua 24:15
  3. #133
    Sep 2010
    Middleville, mi.
    I'm also hoping for no snow for the weekend.
    George, do you have a tachometer on your diesel?
    According to the RPM calculator spreadsheet I have I should have a top speed of 46 MPH at 2500 RPM with 36 inch tires. As I understand it 2500 RPM is a safe RPM upper limit for the 6.2. It can turn faster but doesn't live long above that.
    I don't have a diesel tach and was starting to think I should figure out what my max speed will be in each gear once I get that diesel in.
  4. #134
    Nov 2009
    Greenwood, Indiana
    No tach Paul, but used the same type of calculator and speed limit reasoning. My speedo is off because I'm using the chevy drivetrain, but the axles that I'm putting in is from the truck that the trans and xfer case are out of. I used gps to clock my speed
    Thanks, George
    Joshua 24:15
  5. #135
    Nov 2009
    Greenwood, Indiana
    Rear axle in place. A little painting, then bolt everything down
    Thanks, George
    Joshua 24:15
  6. #136
    Sep 2010
    Middleville, mi.
    Looking good.
    You'll be back on the road before you know it.
    Did you do hydro-boost brakes? Do you have any pictures of that?
  7. #137
    Nov 2009
    Greenwood, Indiana
    I have this pic from a few pages back, but can take a few more tomorrow or Friday
    Quote Originally Posted by Flingarrows View Post
    Hydroboost mounted and plumbed. I may get some time tomorrow afternoon to bench bleed the MC, and run new lines
    Thanks, George
    Joshua 24:15
  8. #138
    Sep 2010
    Middleville, mi.
    Thanks. I did see that one. I guess I was hoping to see what MC was used as well as how the power steering pump is plumbed. But after re-reading I'm wondering if you actually put a power steering box in?
  9. #139
    Nov 2009
    Greenwood, Indiana
    No box, just HB and the pump. PS later on though
    Thanks, George
    Joshua 24:15
  10. #140
    Jun 2009
    Litchfield Illinois
    Looking good. Did you make the pinion guard or did you purchase it somewhere?
