Results 1 to 6 of 6
Thread: warn overdrive
    Default warn overdrive
    Found a warn o/d unit near me for a spicer 18 T-case. Could this be adapted to the 715? I haven't seen it in person to know condition or spline count.
    Did some searching, looks like a no-go. Anyone been looking for one?
    You mean a Dana 18 transfer case? I don't think the Dana 18 is a very stout x-fer case. From what I've gathered it was mainly found in the "smaller" size Jeeps and I just don't know how well it would hold up in a 715.
    Check this link out for some good info. Call the guy up if you would like to, really great guy who is very knowledgable regarding these overdrives.
    www.hermtheoverdriveguy.com
    EDIT: I see you found out more about it.
    68 M-715
    67 M-725
    Yup, thats one of the sites I looked at.
    Chris one of my friends has grenaded a Warn/saturn OD three times. This is in a CJ. Granted he has a 300 HP 350 and uses it, but the weight of the M715 would kill one of these units fast. I have the new saturn version (in the CJ) and don't use it off-road unless it's gravel. After a couple years they need to be taken out and examined for thrust washer wear on the worm gears. Overkill is always good and this OD unit is not suited for the weights we push.
    Liz, covid, murdered 10/19/21
    Jun 2007
    Mountain Home AFB Idaho
    IN CJ's or Willies with either the stock 4 Banger or 225 V6 the Overdrive is perfect and definately the way to go!
  1. Anyone running Warn hubs?
    By porkchop in forum Open Discussion
    Last Post: May 6th, 2008, 10:23 AM
  2. 12 volt warn winch
    By barnaby82 in forum Stock Tech
    Last Post: March 21st, 2008, 02:15 AM
  3. Warn M8274 anyone using one?
    By HUMMER103 in forum Modified Tech
    Last Post: September 18th, 2007, 07:01 PM
