Hi, appreciate all the help in advance. I have 1967 M715 engines been swapped to BBC 454, gears 465, Ford kingpin front.Still has the 200 transfer case and T98 tranny.
I will go with 4L80E with NP 205, this week the FItech fuel injection swap will be completed and I believe I will get the computer for the tranny from TCI. I need advice with regard the driveshaft if someone will recommend a company and also with regard the tranny. The wheels will be 17x14 and tires are 44x19.50. Also do I need to do any modification for the 4L80E to adapt on the divorced NP205? which computer for the 4l80e I should look at, so I can link it with the fuel injection? It will be minimal off-road and 90% highway drive. Thank you
