Results 1 to 3 of 3
Thread: power steering
    Default power steering
    I currently have full hydraulic steering on my Kaiser with rockwell axles with the stock steering column.I want to make this rig more streetable so I want to upgrade to mechanical with hydraulic assist.It is powered by a small block with a stock power steering pump now.What steering box/tie rod set up and pitman arm would work best.
    Thanks for any info.
    Just like the rest of us. Saginaw box from an FSJ or full size GM car 1968-1986.
    You will need to make the Rockwell tie rod on the front which really just means you get to swap the kingpin caps side to side.
    Thanks for your help.I'll try to post some pics when I get it back together and on the road.
  1. power steering
    By no1rifleman in forum Open Discussion
    Last Post: February 15th, 2010, 04:59 PM
  2. power steering
    By RJBM715 in forum Modified Tech
    Last Post: November 26th, 2009, 11:51 AM
  3. power steering
    By desertfox in forum Modified Tech
    Last Post: May 12th, 2009, 01:45 PM
  4. power steering
    Last Post: November 20th, 2008, 08:55 AM
  5. Power steering
    By jfharris in forum Modified Tech
    Last Post: March 25th, 2007, 09:33 AM
