Results 1 to 4 of 4
Thread: modern dually rear end question-selection questions
    KINGSPORT, TN.
    Default modern dually rear end question-selection questions
    i,am going to install a modern dually rear end in my 1972 chevy 1 ton dually truck because of parts availability for the old eaton rears is getting very limited. anyway does anybody know when ( model years ) gm, ford & dodge went to the 8 lug metric bolt pattern ? i need a 14 bolt, dana 70 or preferably dana 80 dually rear end that has the 8 lug on 6.5" bolt circle . i,d really like the dana 80 as it is rear disc brakes. any tips would be appreciated.
    bob
    F-Superdutys from ? to 97 have 10 lugnuts on their Dana 80's
    Superduty's from 99-up have the metric bolt pattern, which has changed once or twice...
    KINGSPORT, TN.
    thanks cap
    Bob, you can put disc brakes on either a 14bolt or a 70 very easily. Many Chevy duallys are 70's...... but if you can find one, I think the extra pinion bearing makes the 14bolt the better choice.
  1. Looking for modern part store seals
    By SAC715 in forum Stock Tech
    Last Post: February 10th, 2010, 12:47 AM
  2. elohim1 : BBC header selection, what did you use?
    By Elohim1 in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 07:48 PM
  3. modern day radio reciever...
    By solekaukini in forum Modified Tech
    Last Post: February 16th, 2008, 07:03 PM
  4. Questions about the rear-rear axle
    By Brian Sisson in forum Stock Tech Archives
    Last Post: May 21st, 2004, 08:06 AM
  5. Rear Main seal questions
    Last Post: January 6th, 2004, 05:50 PM
