  #91
Old December 1st, 2018, 04:31 PM
TXfirefighter TXfirefighter is offline
Private
TXfirefighter is a Soldier
Got the cylinder bracket welded together, cylinder mounted on the tubing bender, then checked the stroke again... the luck! It's about 2" too short
So, back to the drawing board...
Sent from my SAMSUNG-SM-G890A using Tapatalk
  #92
Old December 2nd, 2018, 05:13 AM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
Quote:
Originally Posted by venominjected View Post
wish me luck... I'm hanging the 205 off the back of the ZF without any support. Mine is a street queen so I hope it survives without ripping off the tail housing.
There are a couple companies that make a nice output shaft mount kit that shouln't bee to hard to incorporate...Trail tech fab here in CT (on pirate) and NWF in BC come to mind....
http://www.northwestfab.com/NP205_c_916.html
__________________
Is that real money?
  #93
Old December 11th, 2018, 03:56 AM
Sipos Sipos is offline
Civilian
Sipos is a Soldier
Are both of those companies spot on when it comes to quality, Ray? I'm in need of a shaft mount kit as well.
  #94
Old December 11th, 2018, 01:01 PM
venominjected's Avatar
venominjected venominjected is offline
Corporal
venominjected is a Soldier
I have the original NP200 parking brake system graphed onto my married NP205 so not an option
__________________
1967 M715, 6BT, ZFS542, NP205
  #95
Old December 11th, 2018, 06:53 PM
Private 1st Class
Trail tech makes this too and there are pto cover mounts as well....
https://www.ebay.com/itm/NP-205-Rear...AAAOxyHIlTcLM9
__________________
Is that real money?
  #96
Old December 11th, 2018, 06:55 PM
Private 1st Class
Quote:
Everything I have seen has been....
PTO mount
https://www.ebay.com/itm/NP-203-205-...kAAMXQeW5TcLBX
__________________
Is that real money?
  #97
Old December 12th, 2018, 01:23 PM
Private
Waiting on parts for the bender since the cylinder stroke wasn't long enough.
I had decided the engine and trans mounts were to low and want to raise it 1 1/2". I also want the mounts to tie the frame rails together. So, after lots of measuring, designing and drawing I put my ideas on metal and started cutting. Right now I have the front and rear plates of the crossmember cut out and this weekend I'll start boxing it up.
  #98
Old December 12th, 2018, 05:54 PM
jhartings jhartings is offline
Private
jhartings is a Soldier
Nice! Keep em coming.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
