Page 5 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 41 to 50 of 150
Thread: yes its a total rebuild
  1. #41
    trying to post receiver hitch welded in
    m715 090 by tom boyer, on Flickr
    m715 089 by tom boyer, on Flickr
    reinforced by plating the in side
    m715 099 by tom boyer, on Flickr
  2. #42
    now if I could fix the old post
  3. #43
    engine tear down
    m715 104 by tom boyer, on Flickr
    cam
    m715 108 by tom boyer, on Flickr
    3 mains spun
    m715 109 by tom boyer, on Flickr
    m715 110 by tom boyer, on Flickr
  4. #44
    Sep 2014
    Wichita Falls, TX
    Quote Originally Posted by tomb View Post
    engine tear down
    Holy Smackey.... she already looks pretty tore down..
    I like the receiver. You were right, you're much better in the shop than on the computer!
  5. #45
    right front wheel bearings got water in from a bad end cap
    m715 120 by tom boyer, on Flickr
    m715 121 by tom boyer, on Flickr
    end cap
    m715 123 by tom boyer, on Flickr
    m715 136 by tom boyer, on Flickr
    surface flywheel
    m715 098 by tom boyer, on Flickr
  6. #46
    replacement engine no good still looking, it has a cracked cylinder
    m715 112 by tom boyer, on Flickr
    m715 114 by tom boyer, on Flickr
    m715 113 by tom boyer, on Flickr
  7. #47
    frame sand blasted
    m715 117 by tom boyer, on Flickr
    m715 116 by tom boyer, on Flickr
  8. #48
    I am going with a limited slip on the front worked good on my cj
    m715 125 by tom boyer, on Flickr
    the diff. would not roll out so I had to build a case spreader
    m715 126 by tom boyer, on Flick
    m715 127 by tom boyer, on Flickr
    m715 129 by tom boyer, on Flickr
    m715 130 by tom boyer, on Flickr
  9. #49
    had to build parts to pull the bearings
    m715 132 by tom boyer, on Flickr
    m715 133 by tom boyer, on Flickr
    m715 134 by tom boyer, on Flickr
    had to use a ring gear spacer
    m715 137 by tom boyer, on Flickr
    m715 138 by tom boyer, on Flickr
  10. #50
    frame painted
    m715 147 by tom boyer, on Flickr
    m715 152 by tom boyer, on Flickr
