Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: elohim1 : BBC header selection, what did you use?
  1. #11
    Default over2land :
    Re: BBC header selection, what did you use?
    Post by over2land on Sept 18, 2006, 4:19pm
    Quote:
    If you go to the link below, you can see what the block hugger headers look like in my M715. If you have any questions let me know.
    http://www.geocities.com/ckswayze/index.html
    Do you have a stick or auto?
    With my clutch linkage, the drivers side header you've got won't work for me.
  2. #12
    Default kevins :
    Post by kevins on Sept 18, 2006, 6:16pm
    bluesman2a,
    The puke tank came from Napa(I think) it was a few years ago.
    Also someone else asked about what tranny, I have a T400 connected to a NP205
  3. #13
    Oxford, Ohio 45056
    Default elohim1 :
    Post by elohim1 on Sept 18, 2006, 7:46pm
    Quote:
    Chris, I have an extra set of bbc manifolds from my 1st 366 if you'd like.
    Chris, I may take you up on that.
  4. #14
    Oxford, Ohio 45056
    Default elohim1 :
    Post by elohim1 on Sept 18, 2006, 7:57pm
    Great pics and great info.
    Does not the motor breathe better with headers as opposed to manifolds ?
  5. #15
    Default robertcowan :
    Post by robertcowan on Sept 18, 2006, 10:03pm
    OLDER STYLE BBC MANIFOLDS WONT WORK ON THE NEWER STYLE HEADS I DONT THINK. THE PORTS ARE DIFFERENT.
  6. #16
    Atlanta, Ga.
    Default bluesman2a :
    Post by bluesman2a on Sept 18, 2006, 10:16pm
    Stock manifolds are notoriously constrictive in most cases. Notable exceptions to that would be like the SBC corvette rams-horn manifolds which seem to get pretty good reviews. Yes headers do breathe better, but are notorious for leaking and/or cracking over time. These are not problems one typically has with cast manifolds, they seal better, and generally have much better longevity.
  7. #17
    Post by robertcowan on Sept 18, 2006, 11:19pm
    they do make vette cast iron free flowing manifold-headers for a bbc. and you can always get the old die grinder out and free up the flow alot too !!!! remember alot of flow helps the top end rpm and less flow equals more torque.....
  8. #18
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Post by 40grit on Sept 19, 2006, 8:15am
    chris,
    I was consdiering going with Hooker headers, Hotrod magazine did a test back in 2004 with the zz454, 68-74 chevelle headers ( 1 7/8") did the best job for both low end torque and WFO Hp....(516 HP/560ft-lb)
    just gotta call and see if they'll tell me the measurements to see if they'll fit
    Bob might be onto something also....
  9. #19
    Atlanta, Ga.
    Post by bluesman2a on Sept 19, 2006, 8:52am
    Well color me educated Bob! Did not know that. Thanks for the heads-up!
  10. #20
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Post by 40grit on Sept 19, 2006, 9:36am
    I thought for upgraded performance you were always supposed to go headers, cast iron exhaust manifolds are built for cheapness by OEM, not actual performance like a header. Is there a case where iron manifolds outperform headers designed for the same application?
  1. 230 Tornado Header Flange
    By rpgdeity in forum Modified Tech
    Last Post: October 31st, 2012, 05:20 AM
  2. elohim1 : Radiator in the bed ??
    By Elohim1 in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 08:06 PM
  3. BBC header?
    By spgirard30 in forum Modified Tech
    Last Post: October 20th, 2009, 10:49 PM
  4. New site header
    By compexp in forum Forum for questions and comments on the website.
    Last Post: April 3rd, 2009, 11:42 AM
  5. modern dually rear end question-selection questions
    By BCOWANWHEELS in forum Open Discussion
    Last Post: March 5th, 2007, 08:14 PM
