Old June 20th, 2019, 01:20 PM
randall555 randall555 is offline
randall555 is a Soldier
Default vacume or mechical advance on stock engine ??
do these trucks have a mechanical or vacuum advance ???
also how do you set it and know its working correctly ? my engine runs really flat and has no power on level ground or going up hill . I know these engine aren't known for power but its more than the normal problem
Old June 21st, 2019, 04:00 PM
m38inmaine's Avatar
m38inmaine m38inmaine is offline
m38inmaine is a Soldier
Mechanical advance, the only way I know how to check it would be to use a timing light and see if the timing marks move as the rpm's increase.
Old June 22nd, 2019, 06:15 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Quote:
I would agree with both statements.
Old June 22nd, 2019, 07:59 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
There is no way to set the mechanical advance...it is a problem that the distributor advance weights get corroded and dont move properly so basically there is no advance at all then.
Sometimes one can take the unit apart and clean and get it working, other times a replacement is needed.
If you want vacuum advance, you can try to find a civilian distributor for the 230. These had vacuum advance and regular, car type, plugs and wires. While you lose the waterproof ability and the stock look, you do gain smoother operation and a bit better fuel mileage...though they arent the easiest things to find and you have to make sure the vacuum advance unit works as the replacement supply is all gone years ago.
Old June 22nd, 2019, 10:43 AM
Don Cavey's Avatar
Staff Sergeant
"What he said"....
  #6
Old June 26th, 2019, 06:58 AM
Nailhead's Avatar
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
You will also have to retrofit your stock military carb with a vacuum port, or replace it with a carb equipped with a vacuum port. According to a thread I read on here, the arrangement I'm using (pulling vacuum from the manifold) isn't correct. It seems to work fine, though.
  #7
Old June 29th, 2019, 06:28 AM
brute4c's Avatar
Grand Poobah
Yes, you are supposed to use ported vacuum for the vacuum advance...this would require a new carb as the stock 1920 Holley is not equipped with one.
I did run the vacuum advance on direct vacuum on mine for a year before I changed out the stock 1920 to a civilian 2 barrel intake and carb...no real difference noted in the performance of the vacuum advance unit though I know the direct vacuum sucks on the diaphragm all the time and ported vacuum only does when the throttle plate is in certain positions...so there is a difference...
1998 - 2019
Copyright 1998-2019
