  #51
Old May 30th, 2009, 03:33 PM
gregolma715 gregolma715 is offline
gregolma715 is a Soldier
After I saw what the inside of my fuel pump looked like, I don't think NOS will work. In fact, I rebuilt my carb with a NOS kit and it's getting harder to start and it dumps on acceleration. I am planning on getting a kit with new rubber.
  #52
Old July 30th, 2009, 07:11 PM
fishtail's Avatar
fishtail fishtail is offline
Sergeant
fishtail is a Soldier
Here's what the rebuild kit looks like from AB Linn, I got this in July (09). Costs 45 bucks. For the #1920 Holley 1 bbl. carb. standard for M715. I believe the rubber parts can handle the new gas.
I have not put it in yet. Will reply on how it all went together. Just wanted to add to this post on what's available yet.
Scott
  #53
Old July 30th, 2009, 07:20 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
And good of you to do so! However it works out let us know!
  #54
Old August 9th, 2009, 06:01 PM
fishtail's Avatar
Sergeant
Well, I worked on the carb today, and found out some of the parts in that kit above are not needed for this style (model 3615A).
This kit is from Daytona Parts Company (via AB Linn).
The economizer diaphram is the same (top left on notepad), as is the pump diaphram (top right on notepad). The idle needle (second row up from bottom of notepad) is longer than the stock one, but that won't be a problem, the needle taper is the same as stock. My needle end was totally shot, slightly bent and had a large round groove from being forced into the seat.
What I did need and its not in there is the inlet seat o-ring seal. Mine came out in small pieces. At work we have a huge box of o-rings, I'll have to dig and find one that will work.
I want to clean out the body at work once more before reassembly.
Scott
  #55
Old October 4th, 2009, 06:36 PM
fishtail's Avatar
Sergeant
Well, I did get the carb taken apart, cleaned and redone. Just sat in the truck for a month while I built the second garage. I managed to get time today and put new gas in the tank, hook up the linkages, etc. and start the truck.
The forementioned carb kit works. My inlet O-ring replacement came from the local hardware store, would have been nice if it came with the kit. Many extra parts in the kit that aren't used.
Just wanted to post a quick note about this kit.
Available from AB Linn 704-637-9076. Checking the receipt, the kit was $50.
Scott
  #56
Old October 4th, 2009, 06:45 PM
brute4c's Avatar
Grand Poobah
Thanks for the update!!
  #57
Old December 8th, 2009, 07:03 AM
kyken's Avatar
kyken kyken is offline
Sergeant
kyken is a Soldier
I just sent my carb in to Daytona Parts to get a proper overhaul. Tim and AJ from DP were very help and knowledgeable about the 1920. I got tired of waiting for friends that said they would help and I paid a local guy 50 bucks plus 35 for a NOS rebuild kit and it still did not work well. Wish I knew more about this stuff but I just want to drive. Hopefully, it will be back this week.
  #58
Old December 17th, 2009, 11:47 AM
Ernie Baals Ernie Baals is offline
Civilian
Ernie Baals is a Soldier
Default Carb
Hi
Has anybody have any issues with the rubber parts being shrunk or dry?
I just got a kit form Mark at Saturn. good price, all correct 1960s era jeep corp kit.
The rubber was a tad small an both diaphrams, and after only 2 days they have both tore.
Who, from all the kits listed, has the newest production?
This is in no way a negative towards Saturn, Mark and company are great people to deal with. I have been having carb problems galore since they started adding alcohol to gas.
Thanks Ernie
  #59
Old December 17th, 2009, 12:19 PM
kyken's Avatar
Sergeant
kyken is a Soldier
Hey Ernie,
Got my carb back quickly from Daytona Parts. IT WORKS GREAT and I haven't even fine tuned it yet and I am satisfied. daytonaparts.com Overhaul and shipping $141 and if you want the fancy overhaul with metal parts plated and pot-metal parts anodized, I believe it's about $240.
  #60
Old January 31st, 2010, 02:23 PM
fishtail's Avatar
Sergeant
The rebuild kit from Daytona Parts (via AB Linn), these are all new parts.
Scott
Holley carb info Pineyguy Open Discussion 6 February 23rd, 2013 04:52 PM
Alternative for stock carb and air cleaner Snookie Stock Tech 3 December 30th, 2010 12:45 PM
What carb is stock ? ? Tom @ Snake River Stock Tech 6 May 2nd, 2009 07:51 PM
Stock carb main jet size Jester Stock Tech 9 October 22nd, 2008 11:58 AM
1998 - 2019
Copyright 1998-2019
