Results 1 to 7 of 7
Thread: Paint Removal
    May 2007
    Siloam Springs, AR
    Default Paint Removal
    What have you guys found that works best at prepeping the surface for new paint. My truck has about 3 colors on it and I am ready to at least paint a few parts as I teardown and "make new". My first piece is the front fascia. I plan on a full tear down to frame in a few years so right now I am just interested in protecting the bare metal I have and stopping any future rust but also try to get the truck presentable for weekend driving. Mainly body panels...not frame at this point. Thanks for the help.
    Painting over stuff, then just sand it smooth and shoot.
    Taking down to metal give you a few other options. The best is sand blasting. After that it boils down to money vs. time. Big cup wire brushes work pretty good, but take a long time. 60 grit on a D/A takes a lot longer, but cost less. The fastest non sand blasting thing I have found is this stuff:
    http://www.harborfreight.com/cpi/cta...emnumber=94015
    They cost about $3.00 each and 3 of them will stip a M35 rim in an hour or two.
    The grinder version which cost about $5.00 works real good on body parts. I spent about 2 hours with a 60 grit D/A on my M35 hood a week or so ago and got about 1 foot square down to bare metal. I bought 5 of the grinder versions of the stuff listed above and had the rest of the hood striped in another hour. $30/hour is kind of high though compared to maybe $3.00 spent on D/A paper for about 10 hours to probably finish it. Time vs. Money.
    Washington State
    I would add which ever way you choose to sand your paint or sand down to bare metal, a quality primer needs to be put down prior to any painting. If your doing any body work a sandable primer after the filler and then red oxide or something similiar should be good.
    May 2007
    Siloam Springs, AR
    Any suggestions on good quality primer to use?
    Get the red oxide made by Gillesie. Rapco has it.
    parsons Kansas
    not playing stupid but not a body man either and Ive seen where both gray and red oxide primers allow the topcoat to peal off down the road. is this due to poor prep work? gm and their silver topcoat on 90's vehicles with paint peeling off. Im used to spraying Glasurit paints and limited use of other paints. we had a 57 T-bird that was painted within the last year come in and we was to wash, clean, detail it out and check it all over for its new owner. I had to be the one wash the paint right off it in sheets so we ended up doing a complete paintjob on it. we have done hundreds of Amos Mintor's cars, who sells 55/57 t-birds and from Dallas came down to see the damage and I used a hose and spray nozzle so no real pressure was used.
    any Ideas?
    There was a body shop in Bryan/College Station years ago that used to have a radio add. A really sexy sounding lady talked about surface preperation and how she really liked lots of surface preperation before she did anything. Then some geeky sounding guy would talk about how they would take care of your body.
    The basics still hold true no matter what you are painting or with what. Surface prep is king to paint that stays on.
    The OEM's had trouble making the 2 stage paint systems work right. That was more a matter of cost cutting and "It will work for now" than anything else.
  1. Pully removal
    By Hammer in forum Open Discussion
    Last Post: February 25th, 2014, 06:47 PM
  2. Paint removal and engine mount question
    By dlmos in forum Modified Tech
    Last Post: February 16th, 2010, 05:33 PM
  3. mthomsen : LU4 winch/ paint removal
    Last Post: November 12th, 2009, 03:27 AM
  4. cam removal
    By kevbo in forum Stock Tech
    Last Post: September 14th, 2009, 07:12 PM
  5. Window Removal
    By rboltz in forum Stock Tech
    Last Post: August 3rd, 2008, 05:36 PM
