  #31
Old June 17th, 2010, 12:57 PM
randyscycle's Avatar
randyscycle randyscycle is offline
Staff Sergeant
Location: Rhoadesville, Virginia (five miles from no place)
randyscycle is a Soldier
I'm with Roy on that one. I stopped using any reman parts for brakes a long time ago for reasons mentioned. Too much to chance when the brakes don't work when you need them most.
I even hate to use any reman steering gears and the like, but sometimes there isn't much choice for some components.
"Free advice is worth what you pay for it."
  #32
Old June 17th, 2010, 04:41 PM
vacca rabite's Avatar
vacca rabite vacca rabite is offline
Corporal
vacca rabite is a Soldier
It was a brand new unit. I elected to pay a little more for a new unit.
Hopefully next week sometime the truck will be in my garage and the engine on its way out. Then I will have plenty of space to work with the master cylinder.
This just ed me off. but I am not going to worry about it right now. So long as I can get the truck in my garage, I am going to be able to fix the brakes much easier.
Zach
  #33
Old October 6th, 2010, 01:05 PM
chess's Avatar
chess chess is offline
chess is a Soldier
can soft line like stainless steel dot be used from the mc to the hardlines? also what are the thread size of the fittings where the t is. theres a bunch of sizes mentioned but i just want to be sure i already have my stange engineering mc put on.
  #34
Old October 13th, 2010, 09:32 AM
Alaska hunter's Avatar
Alaska hunter Alaska hunter is offline
Alaska hunter is a Soldier
thanks for the info and pics
  #35
Old August 20th, 2011, 09:44 PM
MJCougler's Avatar
MJCougler MJCougler is offline
Private 1st Class
MJCougler is a Soldier
Default Testing the output pressure of a Master cylinder
Quote:
Originally Posted by Roy View Post
Is it new or reman? We quit using remanned m/c entirely due to high failure/poor quality issues.
One day we pressure tested 12 units from 3 suppliers. NONE of them would supply the 900/600 minimum required pressures.
First test on a brand new AC/Delco unit provide the required psi and then some. I think it tested 1100/800.
After reading this thread, I need to bring it back to the top with a few questions. How do you actually test the output pressure to these master cylinders? Is there a "test kit" sold at the auto parts stores that screws into the master cylinder ports to test the output of a master cylinder?
I put a re-manufactured 10-1371 on my M725 last fall, and now I'm seeing that I should have used a 10-1331 which has a 1.125 bore. And, with the 10-1371 with a 1" bore, I do not have aggressive braking that I think I should have. I have HUMMER tires and recentered rims on my truck that I am trying to stop. Am I asking this master cylinder to do too much? Are these two master cylinders inadequate for this larger tire application?
Any advice? Thanks in Advance,
Mike Cougler, MSgt, USAF Retired, '72-93
'67 M725, VIN 10030, Delivery: 7/67
Rochester, NY
  #36
Old August 21st, 2011, 09:46 AM
Barrman's Avatar
Barrman Barrman is online now
Chief 9-flats
Barrman is a Soldier
There are adaptors to plug psi gauges into brake systems. I would suggest you find a loose gravel or dirt road. Going along at idle, slam on the brakes. You should skid to a stop. Don't move the truck. Get out and verify all 4 tires skidded.
If all 4 tires skidded, get a power booster so the brakes get more psi when at speed or start working out doing leg presses.
If just the front or rear skidded. Then you might have a bad part of the master to the other end, air in the line, or about 20 other things.
If 1 or 2 not on the same end skidded. Adjust your shoes and try again until all 4 lock up.
  #37
Old August 26th, 2011, 12:18 PM
Warthog's Avatar
Warthog Warthog is offline
Corporal
Warthog is a Soldier
There is a thread here somewhere where the poster took all the specs for that different M/Cs and found the Corvette m/c worked the best.
  #38
Old October 28th, 2019, 09:23 AM
MarkODonnell's Avatar
MarkODonnell MarkODonnell is offline
Civilian
MarkODonnell is a Soldier
Default What vacuum booster would you pair with the 10-1331?
This is a great write-up. Thanks for sharing these details. I'm renovating the brake system in my M715 and following your instructions. If you were to add a vacuum booster, is there a booster that would pair nicely with the 10-1331 master cylinder and fit into the M715 without modification?
Any advice is appreciated.
  #39
Old October 28th, 2019, 11:39 AM
Barrman's Avatar
Chief 9-flats
Try and find a Jeep Wagoneer or J truck in a junk yard. There is a wedge shaped piece of aluminum that goes between the booster and the firewall. Its purpose was to move the master away from the carb and up a little.
Going with a 1987 Wagoneer replacement booster would be a good choice in my opinion. Several other have done it already. I went Hydroboost because of the diesel engine on mine the last time I redid it all.
  #40
Old November 28th, 2019, 12:49 PM
ch47fly's Avatar
ch47fly ch47fly is offline
New Recruit
ch47fly is a Soldier
Im new to M715 and would like to install a dual master cycler. Nice job with the write up but pictures are worth a hundred words. Can you repost photos Im not able to view them clear.
gimpyrobb : Master cylinder gimpyrobb PseudoZone - Open Archive 2 November 11th, 2009 01:32 AM
ricepaddycaddy : Master Cylinder Upgrade PseudoZone PseudoZone - Open Archive 8 November 11th, 2009 12:08 AM
Stock master cylinder gimpyrobb Stock Tech 1 June 5th, 2008 06:33 AM
m-715 master cylinder upgrade razrbacman Open Discussion 15 May 2nd, 2008 05:09 PM
master cylinder Q. kaiserkoski Stock Tech Archives 7 April 27th, 2004 06:40 PM
