Results 1 to 3 of 3
Thread: elohim1 : Do you set the motor or manifold level ???
    Oxford, Ohio 45056
    Default elohim1 : Do you set the motor or manifold level ???
    Post by elohim1 on Sept 24, 2006, 7:53pm
    Fred and I have my 502 in the M715 with the th400 hanging off the back . I need to fab a tranny mount, which will dictate how the motor will sit , since we have motor mounts installed.
    The Manifold has an angle to it with the lowest point towards the front of the motor.
    My question is.
    Do you want the surface on the manifold where the carb sits level or the valve cover (motor) level ?
    I assume the manifold so the Carb sits level.
    Chris
    Lone Pine, CA
    Default luckypabst :
    Re: Do you set the motor or manifold level ???
    Post by luckypabst on Sept 24, 2006, 7:57pm
    Yea, level the carb as best you can.
    Default robertcowan :
    Post by robertcowan on Sept 24, 2006, 10:22pm
    put a level where the carb sits, do it longways and side ways
  1. elohim1 : Which 502 motor should I use?
    By Elohim1 in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 04:46 AM
  2. battery charge level chart
    Last Post: May 11th, 2008, 05:03 PM
  3. Power Distribution Box Skill Level One Question
    By hkellerjr in forum Stock Tech Archives
    Last Post: January 19th, 2004, 06:48 AM
