Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 12216 Coming Back To Life
  1. #21
    In the past people have gone to spring shops and gotten straight ones and had them tweak them...seems it is not a big deal for them...
  2. #22
    Jan 2011
    Fernandina Beach, FL
    Quote Originally Posted by GIJoe911 View Post
    Hey Ray, ...
    As for the u-bolt. I’m talking about the axle to leaf spring u-bolt, they look about 9-16” by 8 or 10”. The outside bolt has a little bend in it, so it’s not something I can just get at a hardware store.
    They do look a little odd as you say. I forget but the front is different from the rear. One has the bend; the other one does not? Seems to me that when I replaced the front springs on my truck, I got new "U" bolts from AB Linn (many years ago). I still have the original rear springs. It was easier to replace the springs than try to deal with the rotten bushings. Rear doesn't have rubber if I remember.
  3. #23
    Rear has one that is bent...
  4. #24
    Hello everyone.
    Was able to finish painting the rear of the frame, rear axle, cleaned up and painted the leaf springs and put it back together. After much research I decided to go with Rancho shocks but I painted them black and put black boots on them to help them blend a bit.
    Not sure if these pictures work, but I keep posting them.
  5. #25
    Feb 2007
    Bloomfield CT
    Looking good, keep it up! Did you replace the brass bushings? I think venominjected was looking for the measurements to possibly machine some new ones,,,,
    Is that real money?
  6. #26
    Hello Ray, the brass bushings looked fine on the rear springs. I will be replacing the front rubber bushings.
  7. #27
    Default Updates!!
    How is the build coming along? You were killing it there in January!
